Frozen Cables
   / Frozen Cables #1
Mal AC
Bronze Member
New York
Allis Charlmers 616, Simplicity 3410, Cub Cadet 1605, Allis Chalmers 310
I went out to drive my AC 616 last night and this morning but the throttle cable and the choke cable are frozen. Does anyone know if there is a spray that keeps the moisture out so it doesnt keep freezing? Thanks.
   / Frozen Cables #2
On our snowmobiles years ago we would dip them in uncut antifreeze then reinstall them. worked as a lube an never frose up again:)
Army Grunt
   / Frozen Cables #3
Mal AC
~30~ Years ago I made/invented a pressure device that would hose clamp around either end of a cable . I used a piece of copper pipe and brazed /soldered an air valve stem to set of m/f fittings on one end (you could fill it with oil/grease ..?)an the other had fittings to allow the cable housing to seal inside the pipe.Then to force lube into the cable air pressure it ... back then it was an air hand pump for my dirt bikes ... now I use an air compressor and for tractors & trucks
Ak9
   / Frozen Cables #4
(2) 330 GALLON POLY TOTES (A51248)
(2) 330 GALLON...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
American Farmworks 15 Mile Fence Controller (A51573)
American Farmworks...
16ft T/A Flatbed Equipment Trailer (A50322)
16ft T/A Flatbed...
2008 Ford Ranger Pickup Truck (A51692)
2008 Ford Ranger...
1969 Ford Continental (A51694)
1969 Ford...
