Fuel Dispensing Pump Mobile Phone Safety Alert.
   / Fuel Dispensing Pump Mobile Phone Safety Alert. #1
Junkman
Super Member
North East CT
2003 Kubota BX-22
The Shell Oil Company recently issued a warning after three incidents in which mobile phones (cell phones) ignited fumes during fueling operations.
In the first case, the phone was placed on the car's trunk lid during fueling; it rang and the ensuing fire destroyed the car and the gasoline pump.
In the second, an individual suffered severe burns to their face when fumes ignited as they answered a call while refueling their car.
And in the third, an individual suffered burns to the thigh and groin as fumes ignited when the phone, which was in their pocket, rang while they were fueling their car.
You should know that:
Mobile Phones can ignite fuel or fumes
Mobile phones that light up when switched on or when they ring release enough energy to provide a spark for ignition
Mobile phones should not be used in filling stations, or when fueling lawn mowers, boat! , Etc.
Mobile phones should not be used, or should be turned off, around other materials that generate flammable or explosive fumes or dust, (i.e. solvents, chemicals, gases, grain dust, etc.)
To sum it up, here are the: Four Rules for Safe Refueling
1) Turn off engine
2) Don't smoke
3) Don't use your cell phone - leave it inside the vehicle or turn it off
4) Don't re-enter your vehicle during fueling
Bob Renkes of Petroleum Equipment Institute is working on a campaign to try and make people aware of fires as a result of"static electricity" at gas pumps. His company has researched 150 cases of these fires.
His results were very surprising:
1) Out of 150 cases, almost all of them were women.
2) Almost all cases involved the person getting back in their vehicle while the nozzle was still pumping gas. When finished, they went back to pull the nozzle out and the fire started, as a result of static.
3) Most had on rubber-soled shoes.
4) Most men never get back in their vehicle until completely finished. This is why they are seldom involved in these types of fires.
5) Don't ever use cell phones when pumping gas
6) It is the vapors that come out of the gas that cause the fire, when connected with static charges.
7) There were 29 fires where the vehicle was re-entered and the nozzle was touched during refueling from a variety of makes and models. Some resulted in extensive damage to the vehicle, to the station, and to the customer.
8) Seventeen fires occurred before, during or immediately after the gas cap was removed and before fueling began.
Mr. Renkes stresses to NEVER get back into your vehicle while filling it with gas.
If you absolutely HAVE to get in your vehicle while the gas is pumping,
make sure you get out, close the door TOUCHING THE METAL, before you ever pull the nozzle out. This way the static from your body will be discharged before you ever remove the nozzle.
As I mentioned earlier, The Petroleum Equipment Institute, along with several other companies now, are really trying to make the public aware of this danger. You can find out more information by going to <http://www.pei.org/> . Once here, click in the center of the screen where it says "Stop Static".
http://www.pei.org/static/
   / Fuel Dispensing Pump Mobile Phone Safety Alert. #2
A lot of gas stations in my area have signs saying not to use cell phones.
Last summer I was using a cell phone at a gas station, but I was about 20' away from my car and 30' away from any of the pumps and the clerk yelled at me over the loud speaker. I knew about the hazard, but I also figured I was plenty far enough away.
   / Fuel Dispensing Pump Mobile Phone Safety Alert. #3
Interesting. The Mythbusters tried desparately hard to ignite gas fumes with a cell phone and, if I remember correctly, were unable to. Did I remember this wrong?
Cliff
   / Fuel Dispensing Pump Mobile Phone Safety Alert. #4
   / Fuel Dispensing Pump Mobile Phone Safety Alert. #5
Junkman, you're right about getting back in the vehicle while refueling. And there are some other static producing things that can cause a fire . . . BUT . . . everything I can find on the site you quoted, as well as elsewhere, says the cell phone thing is a hoax; never been one caused by a cell phone. /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
   / Fuel Dispensing Pump Mobile Phone Safety Alert. #6
I think I'll still not use my phone when I'm pumping anything flammable. It's better to be safe than sorry. But then, I've seen real idiots smoking while fueling, I'm not BSing either.
If a person thinks so little of his own life, I don't want to be near him anywhere, I wonder if he was also one of the NASCARwannabes that tailgate you ? /forums/images/graemlins/mad.gif
   / Fuel Dispensing Pump Mobile Phone Safety Alert. #7
Cliff,
Your memory is very good. I just saw a rerun of that show last night. They tried EVERYthing with a cell phone and no KABLOOIES /forums/images/graemlins/grin.gif
   / Fuel Dispensing Pump Mobile Phone Safety Alert. #8
</font><font color="blue" class="small">( I think I'll still not use my phone when I'm pumping anything flammable. It's better to be safe than sorry.)</font>
Most contemporary cell phones are electronically switched w/r/t
power up/down and don't have mechanical contacts which will
generate sparks. An exception here are the small vibrational alarms
which contain a brush-type DC motor. These can and will spark
especially upon initial power up.
Then again the probability of getting sufficient fuel vapor into the
phone case during vehicle fueling seems rather remote.
   / Fuel Dispensing Pump Mobile Phone Safety Alert. #9
</font><font color="blue" class="small">( The Shell Oil Company recently issued a warning after three incidents in which mobile phones (cell phones) ignited fumes during fueling operations.
1) Turn off engine
2) Don't smoke
http://www.pei.org/static/ )</font>
The "MythBusters" (on The Discovery Channel) not to long ago did this test and BUSTED the myth. I don't know what to believe anymore. /forums/images/graemlins/confused.gif G
   / Fuel Dispensing Pump Mobile Phone Safety Alert. #10
First the Email From Microsoft Warning and now this. /forums/images/graemlins/laugh.gif You might want to check your sources the next time you feel the urge to 'warn' us. /forums/images/graemlins/tongue.gif /forums/images/graemlins/cool.gif /forums/images/graemlins/laugh.gif
2025 New/Unused Wolverine Pallet Fork Frame with Forks (A51573)
2025 New/Unused...
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
2018 Kia Soul Crossover SUV (A51694)
2018 Kia Soul...
JOHN DEERE 4066R (A53084)
JOHN DEERE 4066R...
2003 GROVE TMS500E MOBILE TRUCK CRANE (A51406)
2003 GROVE TMS500E...
SAKAI SW502S-1 SMOOTH DBL DRUM ROLLER (A51246)
SAKAI SW502S-1...
