Fuel filter replacement
   / Fuel filter replacement #1
ancote
I did replace the fuel filter, start the engine and it die after 5 minutes.:confused:
It wont start no more, just cranking :(
What could be the problem ? :rolleyes:
   / Fuel filter replacement #3
Welcome to TBN!
Is it a diesel engine? If it is........
Did you fill the new filter with fuel before installing, even if it is self-bleeding?
Did you make sure there is fuel in the tank?
Did you turn the fuel line valve to the "OFF" position?
   / Fuel filter replacement #4
If it's a diesel engine then the fuel system is probably air bound. You need to bleed the injector lines to remove the air from the system. Crack the lines open at the injectors and crank the engine over until you see fuel squirting out, tighten the lines up and it should start.
   / Fuel filter replacement #5
G'day as dieselpower said if it is a diesel then it will need to be bled but it may need to be bled at the filter and pump first if you are not sure how to do this tell us what sort of machine it is and someone may be able to give you step by step instructions:)
Jon
1999 Case 850G Crawler Tractor Dozer (A51691)
1999 Case 850G...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
BOX OF SCHUMACHER 6A BATTERY CHARGERS (A51248)
BOX OF SCHUMACHER...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A53426)
2018 FREIGHTLINER...
2013 Audi Q7 AWD SUV (A51694)
2013 Audi Q7 AWD...
2025 CFG Industrial QK16R (A50123)
2025 CFG...
