Henro
Elite Member
- Joined
- Jul 4, 2003
- Messages
- 4,969
- Location
- Few miles north of Pgh, PA
- Tractor
- Kubota B2910, BX2200, KX41-2V mini EX
Well...I'm /forums/images/graemlins/blush.gif to air my dirty fuel filter...but mine did not make it to the recommended 400 hour change point. I have 392 hours on my Kubota B20910, which will turn two years old at the end of next month.
I have cleaned the fuel filter every hundred hours as recommended in my manual. I get my fuel from a place that seems to be pretty good, high turnover of off road fuel, and never a hint of water...
Tractor started losing power yesterday, then working normally for a while...then losing power again...
It was a restricted fuel filter that was causing the problem.
So I think I will change it every couple hundred hours. But I was wondering what others are doing along these lines... /forums/images/graemlins/smile.gif
I guess worst case I could just keep a spare filter on hand, since they are easy enough to change, but I will probably just change it and be done with it, rather than try to push all the way to the four hundred hour recommendation...
What do you guys do?
