FUEL GUAGE.
   / FUEL GUAGE. #1
WayneAz
mt225e
MT225E FUEL GAUGE HAS STOPPED WORKING,,TRACTOR HAS 300 HOURS AND IS 2020 MODEL.. I HAVE CHECKED IN FUSE PANEL AND IT IS GOOD THERE.. ANY HELP OR IDEAS?? T.I.A. FOR ANY HELP..
   / FUEL GUAGE. #2
Is it always in dry storage? It could be as simple as the gauge is inop. Could be a sending unit in the tank, or the actual gauge.
   / FUEL GUAGE. #3
If all fuses are OK, check the wiring to the sending unit on the fuel tank. Sometimes wires get pulled apart or damaged. With the key switch on, try grounding the signal wire on the sending unit and the gauge should go to full. If it does, the sending unit is bad. If it doesn't, the gauge or wiring is bad.
   / FUEL GUAGE. #4
If you can get at the sending unit, fuel gauges are a resistance reading should be like 0 to 90 ohms. If you are getting a reading somewhere in there, your gauge on the dash could be bad
   / FUEL GUAGE.
IT IS WORKING,,STARTED MOVE SOME TODAY..TESTED WITH A STICK AGAIN AND ALMOST FULL STILL..HAS 3 HOURS SINCE FILL UP AND STILL CANNOT BELEIVE HOW E Z IT IS ON FUEL.. THaNKS FOR ALL REPLIES AND PUT THIS IN FILE "IN CASE" FOR ANOTHER TIME..
2010 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A50854)
2010 TROXELL...
2006 Ford F-150 Pickup Truck (A48081)
2006 Ford F-150...
2018 Vermeer D23X30 S3 Navigator Directional Drilling Machine (A49461)
2018 Vermeer...
2017 UTILITY VS2RA 53FT REEFER TRAILER (A51222)
2017 UTILITY VS2RA...
John Deere 893 Corn Head (A50514)
John Deere 893...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2014 MACK ELITE...
