Fuel Injectors
   / Fuel Injectors #1
marty
Bronze Member
Mid West
Boomer 33D
I have a Ford 4600 SU that I will be replacing the fuel injectors on. Are there anythings I should know ahead of time? Are the injector lines pressurized when the tractor is off? Is it better to replace one injector at a time, then start the tractor?
Thanks in advance,
Marty
   / Fuel Injectors #2
I had all three injectors removed from my Ford 1210 so I could take them to a bud's garage to be checked. Just the normal stuff - don't twist or kink lines, common sense items. I marked them "1,2,3" just in case. Didn't think it should make a difference, but also didn't want to tempt fate. The 1210 has a bleed screw to rid the system of air.
The tractor hadn't been running quite right, but the injectors were OK. Problem went away after I removed the fuel tank and flushed it well.
I'm sure one of the real mechanics here will add vital info you can use............chim
2011 John Deere 5075M 75HP 4WD Loader Utility Tractor (A52377)
2011 John Deere...
SET OF (4) BRAND NEW CHAINS AND BINDERS (A53843)
SET OF (4) BRAND...
2020 KUBOTA RTV...
2010 John Deere LA105 36in Riding Mower (A51694)
2010 John Deere...
JMR tree boom attachment (A53421)
JMR tree boom...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
