Fuel issue
   / Fuel issue #1
Jbenoit
79' MF 245 Perkins diesel
Stop arm o ring was leaking at IP. Installed kit. Springs attached on fuel arm. Key on stop arm to the up (outside) position. Bled system. Got fuel to the IP. 1st line completely off, other 2 loose. Turning motor over for 5 or seconds at a time. No fuel to injectors. Running when I parked it! Any help appreciated.
   / Fuel issue #2
You have a CAV pump I believe and if you didn't assemble correctly, it may not be actually turning on the fuel shutoff under the cover
2018 WACKER NEUSON RTSC3 ROLLER (A53426)
2018 WACKER NEUSON...
UNUSED WOLVERINE PFA-11-3300G HYD PALLET FORKS (A54757)
UNUSED WOLVERINE...
2014 Electric Cart (A53424)
2014 Electric Cart...
2007 Ford F-550 Crew Cab 11FT Flatbed Truck (A51692)
2007 Ford F-550...
2000 Ditch Witch 3700DD Ride-On Trencher (A53421)
2000 Ditch Witch...
TORO TR20 WALK BEHIND TRENCHER (A51406)
TORO TR20 WALK...
