Fuel Line on 51 8N
   / Fuel Line on 51 8N #1
vegaome
New Martinsville, WV
1970 MF-135 and 1951 Ford 8N
Howdy Folks,
I have a 51 8N that someone has put an in-line fuel filter on. I have been reading that rubber hose next the the manifold is not a safe thing. So I just want to put it back to steel. I do have a coil of 3/16 brake line, would this work?
I have tried to search for fuel line size but could not find anything about it. I dont want to have to buy a special line if I can just make it. Thanks and have a good evening.
v/r
Mike
   / Fuel Line on 51 8N #2
I bought a 30" brake line at oreillys it has the correct ends on it just bend to fit. You could make your own if you have the flaring tool and ends.
Howdy carlntexas,
I do have a flaring tool but I don't think 3/16 line I have will work. I'm not a mechanic and I usually break more things than I fix but I have been doing more searching and believe that steel tubing is measured by the outside diameter and that the 8N fuel line is 1/4 line. So 30" X 1/4 brake line and I saw some where that the fitting is 7/16 X 24. I will call the auto parts store in town to see if they have it. Thank you.
   / Fuel Line on 51 8N #4
1/4 is what you need and if they don't have 30" a 36" will work just have more bending to do.
Yup, they had a 30" one for $5.99. The fittings fit the carburetor fitting and I'm figuring the other will fit the bowl. There is a sticker on the line that says, PA-430.
   / Fuel Line on 51 8N #6
I always do the brake line deal, clean n easy
Do you ever put any dope on the fittings or anti-seize?
   / Fuel Line on 51 8N #8
i'd say that you'd have to be a dope to put dope on a flare fitting. the threads don't seal anything. it's the flange that mates up that seals. ;)
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A53473)
GALAXY - SET OF...
2013 KENWORTH T680 TRI AXLE SLEEPER TRUCK (A54607)
2013 KENWORTH T680...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
2021 ALLIANCE NORTH AMERICA, INC AIRMAN SDG45 GENERATOR (A53843)
2021 ALLIANCE...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A52377)
2007 Reitnouer 40...
