Fuel pump
   / Fuel pump #1
jeson
Markusminde, Denmark
Ford 4000
Hi,
My Ford 4000 runs fine, but a couple of times in the last weeks it suddenly stops... When I try to start again nothing happens - the motor turns but it dosen't fire. Because there's no smoke at all I think it dosen't get any fuel. So I try to bleed the fule pump and it starts and runs fine again!
I can't find the reason - it is strange because it just happens now and again - mostly it runs fine. Any suggestions?
   / Fuel pump #2
G'day sound like you might have a blocked filter to me and making the pump suck air, check all your fuel lines from the tank to the inj pump for cracks/looseness
Jon
   / Fuel pump
Hmm... Just thinking it's strange it's not consistently... I'll add a new fuel filter and take a look at the lines...
   / Fuel pump #4
G'day you could also check the fuel tap where it fits into the tank the small strainer screen may be blocked
Jon
   / Fuel pump #6
Ran into a problem like that with a yard sweeper and found that it was a simple fix crap in the tank plugging the outlet then swish the gas and the thing would run fine for a bit. So I agree with jon
   / Fuel pump #7
My Kubota is doing exacty the same thing. I plan to drop the tanks and check the lines and flush the tanks. Hope that will help.
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52577)
2013 UTILITY VS2RA...
2002 JOHN DEERE 450H CRAWLER DOZER (A51406)
2002 JOHN DEERE...
New Idea 483 Round Baler (A50774)
New Idea 483 Round...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A52748)
LIKE NEW 2023...
CPS 185 KD8 PORTABLE AIR COMPRESSOR (A52472)
CPS 185 KD8...
