Oil & Fuel fuel solenoid issue AGAIN!
   / fuel solenoid issue AGAIN! #1
Limecuda
S/E Texas
I go out this afternoon to do a little mowing with my 2006 ck30 hst and it won't start. The lights all work on the dash and the motor turns over. I didn't hear the fuel solenoid engage. Sure enough after pulling it out and hitting the key it will crank.
Last year i had the same issue. The dealer required me to bring it in and found a ground issue. I also had them go ahead and replace the solenoid just in case. My question is where are all of the ground locations for me to check? It is out of warranty and I would rather not spend a few $$$$ if I can find it.
Could it be another issue entriely?
   / fuel solenoid issue AGAIN! #2
Is it a 'ground fault' ?
Did you meter it out ?
2025 KJ K2215 UNUSED Portable Restroom (A47484)
2025 KJ K2215...
Utility Trailer (A45336)
Utility Trailer...
AGT YSRT14 (A46443)
AGT YSRT14 (A46443)
John Deere Pull-Behind Dry Fertilizer Spreader (A44571)
John Deere...
2025 Wolverine BC-13-72W UNUSED 72in Brush Cutter (A47484)
2025 Wolverine...
2025 Wolverine 60in. Forklift Forks (A47484)
2025 Wolverine...
