Oil & Fuel Fuel tank leak on B2710
   / Fuel tank leak on B2710 #1
Von
Veteran Member, Advertiser
Western New York
Kubota B2710
I filled my tractor up yesterday and now have a small leak coming from the sending unit. Had to pull the dash to find it. Has anyone else had this problem? Any Kubota tecs seen this before? and if so what is the fix? I think I'm safe if I don't fill it quite so full. I'll have to run it to see if it stops once the level drops. Thanks for all replys.
   / Fuel tank leak on B2710 #2
Von, I never had that same problem, but I did find out if I overfilled my B2710, the vent/overflow? tube would drip some on the ground and made me think at first that I had a leak. Since you say you pulled the dash to see, you obviously have a different problem. And I also had the fuel tank on the B7100 develop a tiny crack on the bottom where the metal strap went around it to hold it in place.
   / Fuel tank leak on B2710 #3
Is this the time for "Silicone man" to come to the aid of all good tractormen.
Egon
UNUSED JCT 84" HYD ROCK GRAPPLE BUCKET (A51248)
UNUSED JCT 84" HYD...
AGT Mini SkidSteer (A50322)
AGT Mini SkidSteer...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
UNUSED JCT 84" PUSH BLADE (A51248)
UNUSED JCT 84"...
UNUSED FUTURE HYD MINI EXCAVATOR HEDGE CUTTER (A51248)
UNUSED FUTURE HYD...
KUBOTA KX080-4 S2 EXCAVATOR (A51246)
KUBOTA KX080-4 S2...
