Oil & Fuel Fuel Tank Leak
   / Fuel Tank Leak #1
David Cravey
I have s MF 431 and sudenly noticed fuel pouring from the tractor. I found the leak comming from under the Fuel Tank. It appears that the heat from the engine block melted through the tank. I have never had the engine overheat and the tractor has only about 150 hrs. Has anyone else experianced anything like this? It only melted through where 3 bolt heads touch the tank from the engine block and 3 other points below the bolts toward the bottom of the tank. I am curious to know if this is a unique event or if it happens freqently.
   / Fuel Tank Leak #2
Can you post any pics? That may help someone get a better idea.
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2005 Ford F-150 Pickup Truck (A51692)
2005 Ford F-150...
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50775)
WE DO NOT...
2013 JACK COUNTY 130BBL VACUUM TRAILER (A52472)
2013 JACK COUNTY...
New/Unused 7ft 20 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 20...
