Fuel timing 2008 NH T2420 w/ Shibaura N844LT engine
   / Fuel timing 2008 NH T2420 w/ Shibaura N844LT engine #1
Craig Gleason
Ashville NY
New Holland T2420, New Holland TS6.120, New Holland 2120, JD 2510
I bought this tractor used and it never ran well. It was hard to start and lacked power. The hour meter was broken but I suspect it has many many hours on it. After having a New Holland dealer work on it with very limited success, I pulled the engine and just had it rebuilt. I'm now installing a brand-new fuel pump into my newly rebuilt engine. The fuel pump runs directly off the camshaft and you adjust the timing by adding or removing shims behind the pump. I'm following the spill timing procedure in the manual. I verified top dead center and ran the spill procedure several times with the same results. Here's my problem... I cannot get it to advance enough. Even with no shims, I am about 9 degrees too retarded. Does anyone have any ideas for me? Is it possible that the lobes on the camshaft are worn down that much? There is no visible evidence of that but I can't think of what else could be the issue. Any help is appreciated!
   / Fuel timing 2008 NH T2420 w/ Shibaura N844LT engine #2
Idk if it’s written in the manual or not.. but u have to have the pump control rack in a certain position..
All the way 1 way and it’s in shut off..
All the way the other way and it’s in max fuel..
U have to set it in the middle.
Did u take out the center of the delivery valve & remove the spring and torque the holder back down..30 ftlbs..
What are u using for fuel pressure.??
What are u using for a drip tube.??
Are u sure you found TDC.?
Are u turning the engine in the correct normal rotation.??
Last one I did, there were notches in the front pulley..
1 for TDC and the other for the inj. pump..
Good luck
Thank you for the quick reply! Here are the answers to your questions...
No, there is nothing in the manual about this. The rack gets connected to the governor via a thin strip of metal before you install the pump. Should I leave that disconnected while spill timing? The shut-off plunger is removed.
Yes
Just free-flowing via gravity. It requires that you fabricate a tank to bypass the lift pump which I did.
I fabricated a gooseneck tube about 3" long. I get a steady drip which slows as I turn the engine on the compression stroke. I'm turning the engine slowly until the drip gets to 1 drip per sec. then a 1/2 degree after that, it stops completely. That's where I have been checking the timing marks.
Yes. I used a dial gauge on the piston.
Yes
Mine has just one that I verified on the TDC mark. The correct timing is 19-20 degrees before. With no shims, I keep getting 11 degrees before.
   / Fuel timing 2008 NH T2420 w/ Shibaura N844LT engine #4
Do what u have to do to put the rack in the middle..
Use a rubber band or a screwdriver..
The fuel coming out of the tube should be a stream..
Then as you’re turning the engine it slows to a drip..
KEEP TURNING until it slows way down but not off..
THATS WHERE port closure is..
Good luck
Roger that. I'll let you know how it goes.
Keeping the rail in the center and stopping when the drops slowed (not stopped) changed the results to 18 degrees before TDC. I'm going to try it there. Thank you for the help.
   / Fuel timing 2008 NH T2420 w/ Shibaura N844LT engine #7
Thanks to both Craig and "thepumpguysc" for a good discussion. I've enjoyed following along.
rScotty
   / Fuel timing 2008 NH T2420 w/ Shibaura N844LT engine #8
Thank u for trying and posting the results.!!
2006 Volkswagen Jetta Sedan (A50324)
2006 Volkswagen...
2018 FORD F-450 XL FLATBED TRUCK (A51406)
2018 FORD F-450 XL...
GOODYEAR SET OF 9.5-24 AG TIRES (NEW) (A52748)
GOODYEAR SET OF...
John Deere 4020 (A50120)
John Deere 4020...
2010 Toyota Tundra 4x4 Crew Cab Pickup Truck (A50323)
2010 Toyota Tundra...
