Fueling problem w/ JD 790
/ Fueling problem w/ JD 790 #1
nolewatcher
North Florida
5420 JD and 790 JD
I have bought a JD 790 that has been parked the past 2 years. It has only 65 hours on it, but because it has been sitting the valves in the injector pump seems to be stuck. No fuel. I have plenty of supply to the pump, but none out. I read on a forum that I should 'tap' on the pump as I turn the engine over, I will try that tomorrow. But if that doesn't work, what should be the next step?
Well, I tried the "tapping" trick while turning the engine over....there was no luck. Removed the fuel lines at the top of the pump, no fuel at all when I spin the engine over. Any ideas? Will I have to take the pump in for repairs?
/ Fueling problem w/ JD 790 #3
Is there any way that you could "pressure" some fuel to the pump while cranking over. Maybe taking the line off at the tank & using an air hose to try to "force" it into the pump. I would empty the inlet line of fuel, then fill it with Seafoam, then try to force that into the pump. Let it sit for a day & then try starting it.
Seafoam is wonderful stuff for removing varnishes & carbon….. today's fuel is absolute CRAP!
Bandit 250XP Wood Chipper (A63689)
Bandit 250XP Wood...
ATTENTION PLEASE READ (A64119)
ATTENTION PLEASE...
2017 Jeep Patriot 4x4 SUV (A61574)
2017 Jeep Patriot...
INGERSOLL RAND G25 GENERATOR (A58216)
INGERSOLL RAND G25...
2014 Bobcat T650 (A60462)
2014 Bobcat T650...
SQUARE FUEL TANP & HAND PUMP (A63291)
SQUARE FUEL TANP &...
