FX20D Solenoid
   / FX20D Solenoid #1
nazeer4
Washington
Yanmar Fx20D
I am getting buzzing/spinning sound when try to start my Yanmar FX20D. Do I need to replace the Solenoid?
   / FX20D Solenoid #2
Solenoids do go bad. Yet, first check all wiring conditions first. A wire short can be the cause too.
If its the solenoid, what part number is it?
   / FX20D Solenoid #3
Rather than just checking connections remove and clean connectors from battery and battery posts. Tighten securely when reinstalling them. Follow ground lead to frame. Clean and tighten. Charge the battery. Check battery terminal voltage before and during cranking. It should be at least 12.6 before cranking and if it drops to ten during cranking you probably have a weak battery.
2018 WACKER NEUSON CORPORATION DBA WACKER NEUSON LTV6 LIGHT TOWER (A50854)
2018 WACKER NEUSON...
2014 PETERSON 4700B HORIZONTAL GRINDER (A51242)
2014 PETERSON...
2014 Ag Spray Schaben Sidedresser (A51039)
2014 Ag Spray...
2003 STERLING ACTERRA 11FT FLAT BED (A51222)
2003 STERLING...
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A51039)
2013 Doyle Dry...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A51039)
Adams Load Out...
