G1800 engine really slams to a halt
   / G1800 engine really slams to a halt #1
Texwing
Bronze Member
HST3710, FZ2100
Hello I am just starting to go over my new to me 1992 G1800 (400 hours) and after spending some time with it, one odd thing I have noticed is that when I turn the key off, the engine really slams to a halt without turning over a couple of more revolutions. I have two other larger Kubota diesels, and both of those engines gently (but quickly) stop when the key is turned off, the g1800 almost reminds me of a power tool with a brake that violently stops the tool when power is lifted. Seems to turn over and start ok, runs great, I dont get the impression anything is dragging on the machine, but when i turn the key off (at least when the kill solenoid works, its random) the engine seems to come to an unnaturally fast halt. Any comments appreciated.
   / G1800 engine really slams to a halt #2
Mine.. "New to me too" does the same thing and I was told it was normal..
   / G1800 engine really slams to a halt #3
Must be normal.... my TG1860 does the same thing.
   / G1800 engine really slams to a halt #4
Yep, normal. . . On most engines, there's a bigger flywheel and attached clutch pressure plate that keep the engine going for a few revolutions. On our G1800s, there is only a small flywheel and the 5" diameter PTO pulley on the front of the engine. The PTO pulley has belts working as a brake even though they are not tight and engaged. With the long stroke and compression of the little diesel engine, things just shut down in a hurry. When I cut off my engine, it just goes, "RUMP!" and it's stopped.:D
OK, thanks guys, on to other issues with it, but that is/was a big one so it is reassuring to know its ok!
706075 LOT NUMBER 81 (A53084)
706075 LOT NUMBER...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2018 Dodge Charger Sedan (A51694)
2018 Dodge Charger...
2011 FREIGHTLINER CASCADIA (A52472)
2011 FREIGHTLINER...
1265 (A50490)
1265 (A50490)
2025 New/Unused LandHonor Massage Chair Sofa (A51573)
2025 New/Unused...
