G2160 or TG1860
   / G2160 or TG1860 #1
rmc
Bronze Member
South Jersey
BX2200
Not sure which unit to purchase. I live in south jersey and need the unit to cut grass about 1 acre and to clear a stone driveway 200 feet long and 14 feet wide of snow
Any ideas on what unit and should I purchase a blade or snow blower any help is welcome
Also anyone know a GOOD "Price" Dealer in either NJ or Del or Lanchaster Pa or South East Pa
thanks
   / G2160 or TG1860 #2
You would probably be happier with the TG1860 for longevity. I live in Southern DE but don't know the dealers in your neck of the woods, or North DE. The only other thing I can offer is to say that you probably don't want to use a blower or thrower on a stone driveway.
Good luck.
Pete
   / G2160 or TG1860 #3
>You would probably be happier with the TG1860 for longevity<
The G2160 is actually a more heavy duty unit.
I don't know what the $$$ difference is...........but if you can swing it go for the G2160 since you are going to be dealing with snow removal........if you are only mowing the G2160 is probably overkill.
Good Luck, Bob
   / G2160 or TG1860 #4
<blockquote><font size=1>In reply to:</font><hr>
<hr></blockquote>
Dyslexia. You know the drill: Think "A" type "B" Thanks for clarifying.
Pete
   / G2160 or TG1860 #5
See the "kubota g.t. prices" post. It may help.
   / G2160 or TG1860 #6
Do both tractors have shaft drive? The TG series are belt drive I believe, while the G series is shaft. For power delivery and low maintenance, go with the shaft drive.
   / G2160 or TG1860 #7
The deck on the TG is belt drive, but the hydro unit is shaft drive on both.
Keep in mind the belt drive on the TG gives the ability to use an electric pto clutch. I too fought the same question, and ended up with a ZD21. For $1000 less you can get a ZD18. Cuts faster than a LT, more comfortable but less versitile if you need attachments.
2019 Freightliner M2 106 TMA Flatbed Attenuator Truck (A45336)
2019 Freightliner...
2017 KENWORTH T680 SLEEPER TRUCK (A45677)
2017 KENWORTH T680...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A45336)
2003 Big Tex 10PI...
2011 Ford F-250 Pickup Truck (A46684)
2011 Ford F-250...
1997 Dorsey 45' Alumminum Citrus Trailer (A47307)
1997 Dorsey 45'...
2025 JMR 72in Dual Cylinder Hydraulic Grapple Bucket Tractor Attachment (A46683)
2025 JMR 72in Dual...
