G3038h
Tarnold
Ellijay ga
Ls 3038h, ford 1900
G3038h. Dealer can’t get ls to clarify! I’ve broken the rod that makes the F/R pedals to move the tractor. It shows as item 15 on the HST CONTROL parts page . On mine it is a 2 piece rod with ball joints on each end with a turn buckle connector joining the 2 rods allowing for forward/reverse adjustment. My turnbuckle is only 2 inches long. What the referenced page shows a one piece (maybe round or hex) rod with ball joints but could possibly be 15 inches long. Afraid to order cause if wrong it’s mine for about $150. So, does anybody know if this is replacement for what I have?
/ G3038h #2
What broke? The joint? I replaced different version of that setup on my LS using Heim joints. On set the from Amazon and the the ones on the Backhoe from https://midwestcontrol.com/shop/
You just need to know the thread sizes on each end and male or female.
Other places have them cheap as well, like Summit Racing.
Mine has the 10" or so hex turnbuckle like shown in you #15, but a $10 set of 4 from Amazon took care of the issue for last couple of years with spares. Just have to adjust after installing, like you would with the factory parts. I measure everything and found items that match. Bit tedious but cheap.
/ G3038h
Op here. It’s the cast part of the ball joint where the threaded rod screws into right about at the 90 degree I know the rod is m8 1.25.
/ G3038h #4
Like this for example
/ G3038h #5
You can also find sets with both left and right hand threaded joints.
Amazon
A little measuring and searching, and have spares for less money. If you can find them the next time :rolleyes:
