Gas Proof Plastic Repair Sealant?
   / Gas Proof Plastic Repair Sealant? #1
Snap50
A critter in the yard chewed a small hole in our mower's plastic gas tank and I am hoping to find a repair sealant that will stand up to gasoline.
I am guessing a squirrel because there are scratch marks like they leave sharpening their teeth but unfortunately there is a small perforation in one spot.
The mower if old so finding a replacement tank could be a challenge so patching might be the best first shot at it.
   / Gas Proof Plastic Repair Sealant? #2
Best thing to try would be drain fuel out and heat a piece of metal and press against the area to reform and seal tank. You could also find similar type of plastic and add to hole. Weller 2 heat soldering guns have a tip for working with plastic. Good luck with repair.
SealAll claims to be unaffected by gas.
Any experiences with it?
Perhaps the soldering iron and sealant over it.
   / Gas Proof Plastic Repair Sealant? #5
Squirrel did the same to the corner of the SIL old Sears blower fuel tank and it was NLA. I cut strips off the top of a 5 gallon pail and used them and a small propane torch to rebuild it by melting the tank and strips of plastic together. Wasn't really hard but the melted plastic has absolutely no surface tension at all and 5 degrees over melting it would fall thru but I eventually got it.
   / Gas Proof Plastic Repair Sealant? #6
My Speeco woodsplitter fuel tank was chewed through several years back. I used the flat blade attachment on the soldering gun and welded it using strips of "filler rod" from a old antifreeze jug. It worked great and doesn't leak.
   / Gas Proof Plastic Repair Sealant? #7
Have you seen this type of repair????
willy
   / Gas Proof Plastic Repair Sealant? #8
For the white plastic fuel tanks used on some mowers. A hot glue gun will seal the hole and is not effected by gas.
   / Gas Proof Plastic Repair Sealant? #10
Body shop guys do amazing things with Rapid-Fix!
Check it out!
Good Luck!
2008 JOHN DEERE 270D LC EXCAVATOR (A51246)
2008 JOHN DEERE...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2013 Ford F-150 Pickup Truck, VIN # 1FTFW1EFXDFB07930 (A51572)
2013 Ford F-150...
2004 JOHNSTON STREET SWEEPER (A52577)
2004 JOHNSTON...
FRONTIER FAV20 LOT NUMBER 68 (A53084)
FRONTIER FAV20 LOT...
