GATOR 6x4 (gas) carburetor repair
   / GATOR 6x4 (gas) carburetor repair #1
growland
Gator 6x4 sat for 2 years. New gas in tank (now), lines purged, Gas filter replaced. Looking for maintenance/adjustment regarding carburetor. Operates 'well', but only with choke 30-40% out, gas constantly dripping out of purge tube. What does the adjustment on the carb bowl do? There is a black plastic adjustment screw (needle valve?), but rotation is limited by metal tab, which seems to help. Can/should this be further rotated (requires bending metal tab up). Other than replacement, is there a rebuild kit available? Thanks.
2018 International DuraStar 4300 TMA Attenuator Truck (A52377)
2018 International...
2012 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2012 Ford F-350...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A51247)
2017 CASE IH 580...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
12in Mini Excavator Tooth Bucket (A52377)
12in Mini...
