Dirt Moving GC1700 Series and a Single Bottom Mold Board Plow
   / GC1700 Series and a Single Bottom Mold Board Plow #1
jlgurr
Veteran Member
Bostic, NC
Massey Ferguson GC1705, John Deere STX46
Anyone with a GC 1700 series using a single bottom "turning plow" successfully? I have an opportunity to purchase one but was cautioned that our SCUTs may not be tall enough for such an attachment.
Thanks,
Jeff
   / GC1700 Series and a Single Bottom Mold Board Plow #2
Most implements need to be designed for a subcompact, or modified, to work well. But, some report being able to use standard implements, as is.
If all else fails, more lift could be accomplished by making the arms longer, so it may not be a big deal.
If you buy a category 0 sleeve hitch, you can get an old Brinley sleeve hitch plow, used. They are made garden tractors, so it will work fine.
   / GC1700 Series and a Single Bottom Mold Board Plow #3
Another possibility is to add an inexpensive 3pt quick hitch . . . As they also lengthen the arms reach too. I would think the gc1700s would be pretty good for most implements because their rise height and wheel clearance is better than some other scuts.
Can you stage the plow on some concrete blocks to tape measure height clearance needs ?
E-Z-Go ST350 Utility Cart (A55851)
E-Z-Go ST350...
2022 John Deere 5075E MFWD Tractor (A53485)
2022 John Deere...
AGT SAII100 SKID STEER QUICK ATTACH 48" (A57193)
AGT SAII100 SKID...
1985 International 1754 Material Spreader Dump Truck (A51692)
1985 International...
golf cart (A56859)
golf cart (A56859)
2005 MACK TRI AXLE DUMP TRUCK (A57192)
2005 MACK TRI AXLE...
