GC2310.......miss
   / GC2310.......miss #1
67PLY
PENNSYLVANIA
MASSEY GC2310
My tractor will miss every once in a great while -- will have a miss in the engine (like two or three times)....then runs fine for several hours. Kinda sounds like a gas motor when running out of gas. It is not consistent with any one paticular activity. Has around 120 hours. Any ideas??????? Just started doing it this spring. Thanks
   / GC2310.......miss #3
Like Steve said, I would guess your miss is from water in the fuel.
   / GC2310.......miss
How do I check.......or should we drain the tank. If I drain all of the diesel fuel out -- how do I prime the engine? Are there any safe additives to put in the fuel to prevent the problem? Thanks.........................
   / GC2310.......miss #5
Dose the GC2310 have a clear cover over the fuel filter? If it dose I would assume you could see the water in the lower part of that cover, it is real easy to see fuel on top of water.
   / GC2310.......miss
It did it again today.........but heard a click...like when you get off the seat when in the drive mode. Only lasts a second then runs fine. Maybe its one the eletrical safety switches???
2021 Isuzu NRR Heil 9Yd Mini Rear Loader Garbage Truck (A50323)
2021 Isuzu NRR...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50774)
PLEASE CHECK...
2007 KUBOTA M5040F TRACTOR WITH LOADER (A51243)
2007 KUBOTA M5040F...
2012 Toro Greensmaster 1600 Walk Behind Mower (A48082)
2012 Toro...
2021 CATERPILLAR 317 EXCAVATOR (A51242)
2021 CATERPILLAR...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2017 FREIGHTLINER...
