GCK60-23bx
   / GCK60-23bx #1
CT_Kubota
N.W. Ct
BX 23
I have the chance to pick up a used grass catcher, can someone tell me if the GCK60-23bx will work on a BX23? It's coming off a bx24.
thanks
   / GCK60-23bx #2
Could you give me the model of the deck on your tractor? There are a couple of possible glitches but the most expensive kit to adapt is only 141.
   / GCK60-23bx
Art, Thanks for the reply. I have a rck-54-22bx deck. From what I've found the catcher will not mount to the back of my tractor because they changed the backhoe mount when they went to the BX24. Any ideas you have would be appreciated.
   / GCK60-23bx #4
Can I ask what a used GCK60-23bx goes for these days? I have a lead on one but don't know what it's worth.
   / GCK60-23bx
Any Idea what the part number is for this kit and what it takes to install?
   / GCK60-23bx #7
They don't add the BX23 to the list on the kit that I'd made mention of but it does make it fit the rest of that vintage tractors. BX3042
The other kit BX 3086 is for the difference between the BX24 and 25 and is only thirty dollars.
Depending on your abilities with torch and welder a little fab work can make it look easy.
   / GCK60-23bx
Unfortunately I don't have any access to a welder. The dealer that I picked the catcher up from sent me the Kit. I'm hoping that with a little modification, I can make it work. The only thing I'm concerned about is that it may be too long and hit the bottom arms where the backhoe sits. I'll see soon enough, I just got notification that the kit is out for delivery today.
   / GCK60-23bx
Looks like I'm out of luck. the hooks for the backhoe are right where the brackets need to be. Without some creative welding, I'm not going to get it to work. I thought about mounting the brackets on the inside, but they end up about an inch too close for the support arms for the bagger. Back to the drawing board.
   / GCK60-23bx #10
CT Kubota, Interested in selling it?? I have a BX24 and have been looking for a bagger and cutting deck. PM me if interested
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
LandPride PFL1242 Pallet Forks (A50120)
LandPride PFL1242...
2017 John Deere 855D 4x4 Gator Utility Cart (A50322)
2017 John Deere...
2008 Genie S-65 65ft Telescoping Boom Lift (A50322)
2008 Genie S-65...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
CFG Industrial Q.A Auger (A50121)
CFG Industrial Q.A...
