Gear box maintenance on mid mount mowers and other implements.
   / Gear box maintenance on mid mount mowers and other implements. #1
AxleHub
Elite Member
Western Wisconsin
Massey scut 2015 GC1715
I recently made a mistake to not put this thread on the General Owner/operating forum . . so I'm now correcting that error.
This topic can apply to all scuts and cuts that have a mmm
The gear box on a mmm. Its pretty easy to forget it when you're focused on the tractor engine and hydro servicing needs. And besides the mmm . . maybe there are other implements that you have a gear box and oil to be changed too.
Recently I drained the gear oil out of my mmm gear box (after about 40 hours of actual mowing use - manual recommends 50 hours) These gear boxes aren't large . . a quantity of about 13 oz. in my particular gearbox. I tipped the mmm up to a vertical position to make sure the 1st change was drained as much as possible. And a good thing I did. Lots of shiny fine grit . . Lots of it. Normally a very light honey color . . the color that came out was a deep gray and not transparent at all. Its natural after 40 hours of operation of a new mmm that it would have some with all the fine gears and surfaces. No pieces or chunks . . but did I mention LOTS of shiny grit in the oil.
Getting out contaminants and metal grit is important to eliminate wear on the gears as they spin fast . . and of course no filter to catch contaminates.
I put in a synthetic gear oil now. 13 oz deserves all the benefit it can get :) Especially when you figure it's another 150 or 200 hours to the next scheduled gear oil change time (but I will test ut sooner just to make sure.
I was surprised at just how much grit was in the oil. So have you thought to change your gear oil recently in your gear boxes ? I'm surprused at the result but sure glad I did it . . clean oil for machines is like clean water for us.
Doosan Forklift (A51573)
Doosan Forklift...
2025 New/Unused Wolverine Brush Cutter (A51573)
2025 New/Unused...
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A53472)
2019 Energreen EVO...
Kubota KX91-3S2 Mini Excavator (A52377)
Kubota KX91-3S2...
2019 Nissan Sentra SV Sedan (A51694)
2019 Nissan Sentra...
1996 International 4700 Box Truck, VIN # 1HTSCABP2TH265415 (A51572)
1996 International...
