Gear Box Woes on Rotary Cutter
   / Gear Box Woes on Rotary Cutter #1
Papasmith
Bronze Member
Ruffin, NC
4500 Mahindra
Gear box on my 7ft rotary cutter leaked out the oil and by the time I noticed it, the main gears were shot. I understand that this model howse cutter had a 100 hp gear box which seemed excessive but, that's what I understand.
Does anyone know where I can pick up a good and inexpensive gearbox in the 75 to 100 hp range? I tried agri supply but, they didn't have anything that I could see.
   / Gear Box Woes on Rotary Cutter #2
Are the gears shot or the bearings?
   / Gear Box Woes on Rotary Cutter #3
I broke a gear in a Bush hog brand batwing once. If you can get the gears, bearings and seals from Howse it is not difficult to rebuild the gearbox as long as the housing isn't damaged. The bearings and seals should also be available at an independent bearing supply. Be sure and get the spacers that adjust how tight the gears mesh when you order the gears though. Too tight will cause them to heat up in a hurry.;)
   / Gear Box Woes on Rotary Cutter #4
How about these guys, or these guys. The latter seems to sell only Howse parts...
If you have the HD7, they list the gearbox: G104 75 PRC81146 GEARBOX, 100HP 7' & 8' CUTTER (CHEETAH) $315.31
   / Gear Box Woes on Rotary Cutter #5
I just got Agri-Spply's catalog and they show a 75 hp gear head. bjr
   / Gear Box Woes on Rotary Cutter #6
Try Dn equipment
Mt. Orab Oh
1 877 885 4300
I bought a new 60 hp box from them for 210.00
Blade pan, bolts and 2 sets of blades shipped to Mn for $480.00
Ken
2121 (A51244)
2121 (A51244)
2010 UTILITY TRAILER MFG. CO. 53 FOOT FLATBED (A53843)
2010 UTILITY...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53473)
NEW HOLLAND 706 30...
WHISPERWATT DIESEL POWERED GENERATOR (A53843)
WHISPERWATT DIESEL...
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A53473)
2020 Massey...
Loader bucket (A53117)
