Gear Grinding
   / Gear Grinding #1
CRaymond
Kubota B7610
I’m interested in feedback on a situation I’m experiencing:
I have a new 7610 w/MMM and recently purchased a rotary cutter. I found that disengaging the rear PTO (540) caused heavy grinding; specifically, I could not put the PTO gearshift lever in neutral with the clutch depressed. Only after letting the rotary cutter come to a complete stop could I release the clutch w/the gear shift lever in neutral.
My dealer told me that when operating a rear PTO implement I need to detach the MMM drive shaft. This worked for a short while but I’m now getting grinding again when I put the gearshift lever in neutral.
Does this seem normal?
Any advice is much appreciated.
   / Gear Grinding #2
It almost sounds like there is an overrunning clutch in there. Ask your dealer if there is.
   / Gear Grinding #3
What RPM are you at when disengaging the PTO?
If you're doing this at PTO RPM (2600 or so), I'd reduce the engine speed to 1200 RPM...
If your tractor doesn't have a tach, just throttle down as low as you can.
2025 ZWB 59in Excavator Boom Mini Skid Steer Attachment (A55787)
2025 ZWB 59in...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2019 FREIGHTLINER...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2013 RAM 4500 (A50323)
2021 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A54313)
2021 FREIGHTLINER...
