Gear oil
   / Gear oil #1
bugwizard
Bolens G272
Just joined forum, looking forward to sage advise...I own a 1987 Bolens G272 diesel tractor. The manuals say to fill transmission with 36 quarts of SAE80 gear oil.
No where is it specified a GL-4 or GL-5. They are different, so I don't understand not stating which to use.
   / Gear oil #2
I wouldn't get hung up on the difference with a "seasoned" tractor of that vintage. Just putting new, correct weight oil in it is the important thing. 👍
   / Gear oil #3
Since you have the oil on the transmission drained, it's a good time to pull the screen out and give it a good cleaning, if it has one that is.
   / Gear oil
I'm changing the hydraulic oil filter once I establish the correct gear oil designation.
Thanks for your reply.
   / Gear oil #10
Bugwizard, you say you’re changing the hydraulic oil filter. Do you mean you’re putting in a new strainer element or are you changing it out for another filter altogether? I ask because I’m having issues with my g274 strainer. The mechanic tore the old one up (I have no idea how) and put the housing back on and didn’t say anything. I Found the strainer tossed in the yard and had a look inside and sure enough it was empty. He’s since been given the boot and I’ve been looking for a solution that doesn’t require me to buy a new one from overseas. Also, what filter do you have fore the engine oil? He also threw on a spin on hydraulic filter for the engine oil. I can’t seem to find specs for filters anywhere so whatever you have on yours must be better than mine.
2015 Dodge 5500 4X4 Bucket Truck (A53472)
2015 Dodge 5500...
8ft x 6 1/2ft Shipping Container with Side Door (A51573)
8ft x 6 1/2ft...
2018 FORD F-550XL SERVICE TRUCK (A51406)
2018 FORD F-550XL...
Toro ProCore 864 Series 64in Turf Aerator Tractor Attachment (A51691)
Toro ProCore 864...
Clark G500-50 4450lbs Propane Forklift (A51691)
Clark G500-50...
2017 Peterbilt 567 Day Cab (A52384)
2017 Peterbilt 567...
