Gear v Chain
/ Gear v Chain #1
randy41
Veteran Member
Linden VA
I'm going to buy a new 48" tiller. I looked at the KK and the offset is on the wrong side for me. It also seems excessively heavy. Theres a chain drive Bush Hog one at the NH dealer in Salem for $1300. then theres a Taylor Way in Wytheville for $1500 but i think this one is all gear driven.
opinions?
i grow veggies on 2 acres and my field is set (and my mind is too)for a 48" width. i have a 1710 tractor. my old tiller has too many problems that will take too long to fix. had it for 20 years. I am 58 and don't expect to be growing this much when I'm 68.
/ Gear v Chain #2
My tiller is chain drive. The chain does wear out and has been replaced three times. It has also been broken a few times. It's always real greasy fun changing the chain. The hands don't clean up for weeks!:D :D
As to what is better That is another question that will raise debates. Gear drive may win out?:D :D
/ Gear v Chain #3
HELLO TO ALL,
KK does make a chain drive in the smallest tiller.
the larger ones are gear drive. i got some information
on the KK because if was thinking about buying one. i
also want to look at the LAND PRIDE. they make a fine
machine.
accordionman
wlbrown
/ Gear v Chain #5
opinions?
The other point is that a chain drive tiller requires less hp than a gear driven tiller...compare KK gear driven vs LandPride chain drive on HP requirements...
/ Gear v Chain #6
Chains only a little more efficient. Id expect them to be within 5% of one another if they are using the same ratio and operating [power sufficiency] comfort margin.
larry
/ Gear v Chain #7
Wombat125 said:
Nitrile gloves are your friend...
Absolutely! I "discovered" rubber gloves and nitrile gloves and they are a must for anthing greasy. Wombat125 gives good--no make that great advice for messy work.
I buy mine at Sam's Club.
/ Gear v Chain #8
I have a 48" KK gear drive and it's been a good one. Why is the offset a problem? I paid $1K for mine a few years ago. They will take a beating, slip clutch is nice too, no shear pins for those inevitable hidden obstructions.
John
/ Gear v Chain #9
The gloves may work for most things but those little clips that hold the chin pins in place???:D :D :D
There is also the little matter of jumping grease!:D :D :D
2022 John Deere Z930M (A57148)
2022 John Deere...
2022 BIGHORN EXPLORER 400 EFI UTV (A62130)
2022 BIGHORN...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
Zero Turn Mower (A59231)
Zero Turn Mower...
BUNDLE OF 4"X RANDOM LENGTHS RED OAK FLOORING (A62131)
BUNDLE OF 4"X...
