Gehl 4500 Skid Steer Boom/Lift arm weak erratic
   / Gehl 4500 Skid Steer Boom/Lift arm weak erratic #1
r8f1k
Farmall 100, Allis Chalmers D14, International Super MTA, IH 560, Mahindra 4510, Gehl 4500, Clark CY45, JD 800, JD 60
Just installed a professionally rebuilt lift cylinder on the left side. Now, once in a while the boom will rise VERY slowly and if you let go of the handle the boom will drop right away. It will do this over and over until you move the skid steer or shake the bucket. Then, it will work fine for quite a while. Did I get something in the system? Dirt, flakes, etc? Do I pull the relief valve and clean it? Is it the check plug? Spool problem? Clean fluid, full system, doesn't matter if the skid steer is hot or cold. Any thoughts?
2009 Kubota KX080-3 Mini Excavator (A51573)
2009 Kubota...
2005 Ford F-150 Pickup Truck (A51692)
2005 Ford F-150...
2025 New/Unused Wolverine 48in Skid Steer Trencher (A51573)
2025 New/Unused...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A53472)
2022 NEW HOLLAND...
2019 Freightliner M2 106 Sweeper Truck, VIN # 1FVACXFC1KHKF6139 (A51572)
2019 Freightliner...
