Generator monitoring
   / Generator monitoring #1
RalphVa
Super Member
Charlottesville, VA, USA
JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
I just went through having to recharge the battery on my generator. The battery tender I had on it went out.
I wonder if anyone has used some generator monitoring equipment/gauges to put on my inside electrical ATS panel to monitor battery voltage and generator load/kw.
Having trouble finding what I want on line. Plenty of battery voltage or some form of generator load displays, but I can't seem to find any that give me both generator load and battery voltage.
Thanks.
Ralph
Can, but it's dirt easy to just go out and measure voltage on the battery. Figured if I do anything in the panel (that has battery voltage to it from the generator to run the ATS) that I wanted one meter to do it all.
Ralph
   / Generator monitoring #4
Ralph
Ok, i can see why that would be handy. One meter to rule them all. :D I suppose it would have to be able to read ac and dc voltages, there's gotta be something out there to do that. If your into DIY im sure you could find something in the arduino forums. People are using those for all kinds of crazy things so it seems something as sensible as this should be out there. Im going to try one to use as a light controller for led light strip.
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
2012 UNVERFERTH 15-INCH REAR SPACERS FOR 10 BOLT HUB (A52748)
2012 UNVERFERTH...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2016 Peterbilt 320...
Komatsu PC56 Excavator (A51573)
Komatsu PC56...
2011 TROXELL 130BBL (A52472)
2011 TROXELL...
2005 NEW HOLLAND DC95WT CRAWLER DOZER (A51406)
2005 NEW HOLLAND...
