Richard
Elite Member
- Joined
- Apr 6, 2000
- Messages
- 4,993
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
My understanding with a geothermal system is you can have an open loop or a closed loop. I suppose each has their pros/cons.
With the open system, one way to get rid of the water is to dump it into another well dug into the ground (or so I've read)
I've also read that this can cause issues with your main well as it might change the temperature of the water.
My well is about 300' down if I recall but, its flow rate is slightly over 100 gallons/minute. Seems we have a good flow of water.
So, if we did a geothermal system, dug a second "dump" well say, within 20/30 feet of my existing, would the flow rate of the well be enough to not be too worried about mixing of the two waters?
Second, is there any way to ascertain which direction the water flows down there such that we could perhaps drill a well "downstream"?
(my understanding is a well weeps water into the hole, it isn't like an underground river)
Thoughts?
Thoughts?
