milkman
Elite Member
- Joined
- Sep 22, 2001
- Messages
- 3,555
- Tractor
- BX2200, BCS 735
I thought I'd post this since it looked really scary at the start. I had to replace a power steering hose that run under the floor board of my BX2200. The hose was routed under the floor and also into the engine compartment on the left side of the engine, then up under the dash to the steering control.
First I removed the grill guard, then the lower engine cover.
Removed the screen covering the battery, also the plate under the battery.
On the right side, by the seat, remove the plastic handles on the 3pt control lever, the 4wd engage lever and the hydro speed control. Remove the three phillips screws under the fender, and remove plastic panel.
Pull the hairpin key and remove the seat. Then the knobs for the deck height adjustment pulls off, and also the descent speed control for the 3pt hitch, it just pulls off also.
Remove the two bolts that hold the hydro forward-reverse pedal.
Remove the two 13mm hex bolts, one on each side by the seat, two 13mm on the front edge of the floorboard and then the four nuts under the back of the floor board. The floor will lift off since the holes for the brake pedal and the differential lock are cut out to allow removal with out taking them off. I had to remove the left rear wheel to get to the line fitting.
There are four lines run to the steering control under the dash, and they are hard to get to, just don't mix them up if you take them all loose, that would be hard to get used to, steer right, go left!!!! /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif
