Paddy
Veteran Member
Hello
With Winter soon around the corner, time to make sure the house is sealed up. The one weakness I have found is garage doors. The one I have is a new Overhead door brand. It is a solid and well insulated. The issue I have is the sealing at the lower corners. The top and sides have a rigid plastic strip with a rubber flap. The bottom has the classic foam hollow circle that flattens as the door comes down. The bottom is sealed along the length.
The problem is how garage doors are mounted, flush to the inside framing. This makes the center of the door an inch away from the framing. In the dark, you can take a flash light and see there is quite a large hole where the foam round lower gasket doesn't meet with the side flaps. Mice have found this and chew away. A short term, keep the cold out is to stuff soft foam in the corner before closing.
It just seams like a bad design. The big soft bottom gasket is designed to allow for uneven floor issues. I'm thinking of replacing it with a thinner solid foam gasket. I figure if I can get the door with 1/4" of the floor, no mouse is chewing it's way in. Then use a block of wood to fill in the gap.
Anyone else notice how bad garage doors seal?
Paddy
Paddy
