Glow Plug question
   / Glow Plug question #1
BHarrison
Baton Rouge, LA
Kubota ZD21
Hello All. I just bought an old toyota diesel pick, and the glow plugs are not working. Well, I can replace them easy enough. One thing I find myself asking is, how do you know when one goes out? It's pretty obvious when 3 or 4 go out, (on a 4cyl)
but how do you tell if you lose 1 or 2?
I guess you could measure total current, but I don't have anything that measures 80 amps!
   / Glow Plug question #2
Here's how I check the glow plugs on my F350 - I have a wire with alligator clips on both ends, attach one to the positive terminal of the battery and they touch the other end to the glow plug, if I get a spark I know the plug is working somewhat, if not spark, then I know its open and should be replaced. On the Ford, the glow plug controller depends upon the resistance in the glow plugs to function correctly. If a glow plug goes, you notice the controller cycling faster then if all are working. Don't know about the Toyota. Hope this helps.
There is a controller, and some sort of resistance measurement happening. The glow plugs have power for about 90-120 seconds after the key is first turned on. I have ordered the OEM service manual, and will learn more when I get it, but I'd like to attack the glow plug issue promptly.
Will it hurt the engine spinning over without the glow plugs on?
   / Glow Plug question #4
Ben,
You can check them just like Halsey said. Also it won't hurt to turn it over without the glow plugs on.
Is there a way to tell if you have one out while it's still in the engine?
What's the first indication that one is out?
   / Glow Plug question #6
<font color=blue>...Is there a way to tell if you have one out while it's still in the engine?...</font color=blue>
Simply disconnect the B+ lead going to each individual glow plug terminal and ohm it out from that terminal to ground. {Warning... Not all glow plugs operate on 12volts... some operate much less (the controller pulses the B+)... so it's not advisable to "just hook up 12 volts and test for smoke...?"}
A good glow plug will read ~~1-3 ohms {or a very low resistance}. A bad glow plug will read open or infinity. A glow plug is nothing more than a "miniature heating element" with a controlled "on" time.
While the B+ wire is off you can check for voltage at that plug with the switch on.
Hard starting is one indication a glow plug or a few are out...
   / Glow Plug question #7
Ben,
If you have a voltmeter capable of measuring millivolts, you can measure the drop in the wire to the plug when the glow plug is on. At ~10-15 amps/plug you should be able to see a few 10's of millivolts for a plug that is operative, zero if it's not.
Al
Thanks everyone. So, is it common practice to periodically pull your plugs, and chaeck them, or just when it gets hard to start?
KC 78in. Skid Steer Bucket (A49339)
KC 78in. Skid...
2013 AMSIG Message Sign Board S/A Towable Trailer (A46683)
2013 AMSIG Message...
1967 Ford F600 Grain Truck (A49339)
1967 Ford F600...
2011 Ford Fusion Sedan (A46684)
2011 Ford Fusion...
2006 Ford F-550 Service Truck (A43476)
2006 Ford F-550...
Wolverine TCR-12-48H SKid Steer Trencher (A47371)
Wolverine...
