Going up hill no power, but zooms up hill in reverse proper
   / Going up hill no power, but zooms up hill in reverse proper #1
Dreq
Pottsville, PA
Simplicity ZT 16 HP 44" Deck
It was suggested to move this post to hydraulics.
I have a Simplicity ZT Series 16 HP with a 44" Deck. It is a zero turn mower that is about 12 years old.
This season it started great, but something is different. When I go uphill in reverse, I have plenty of power and I zoom right up the slope. When I try to do that going forward I come to almost a complete stop. If I back off the controls, it feels like it is trying to catch. Then it catches and I can proceed very slowly. The engine runs like a champ the whole time. No stuttering at all. But I have less go to almost a stop.
I have topped off the fluid which was a little low, but I have cut three more times and it still doesn't call for more.
Last year my uncle, who is far more mechanically inclined than I, changed the rider drive belt.
What is totally weird to me is that when I go up the hill backwards, it is a smooth work horse. When I go up forward it slows and stops and then gets to a slow walking pace.
My friend suggested changing the transmission filter, but the manual I have doesn't list one on the parts list.
Any ideas? or is it time to replace after 11 seasons?
http://bsintek.basco.com/BriggsDocumentDisplay/default.aspx?filename=jgEDGP_dsK5tG6EWj7mRgtLvBCd6
http://bsintek.basco.com/BriggsDocumentDisplay/default.aspx?filename=jgEAGP_dsH0tGaEWj7mRgtLvBCd6
   / Going up hill no power, but zooms up hill in reverse proper #2
Since this a Zero Turn I would presume two separate HST units. If it is two separate units it sounds like a problem with the input drive belt. Would be an uncommon failure to have both HST units fail at the same time. Usually one side gets weak but not both.
   / Going up hill no power, but zooms up hill in reverse proper #3
If the drive belt was installed backwards or flipped it will have rapid wear and slip. I had a jd110 tractor that had a similar issue caused by an incorrectly installed belt.
2001 International 3800 4X2 School Bus (A50860)
2001 International...
Xmark 72 zero turn (A50490)
Xmark 72 zero turn...
KUBOTA L39 BACKHOE (A50458)
KUBOTA L39 BACKHOE...
2015 International DuraStar 4300 Crew Cab Mason Dump Truck (A48081)
2015 International...
2012 DODGE RAM 5500 HD SERVICE BODY (A50505)
2012 DODGE RAM...
2017 Ford Explorer XLT AWD SUV (A48082)
2017 Ford Explorer...
