Gooseneck Questions
   / Gooseneck Questions #1
tractorski
southern Vermont
Branson 3510
I am looking at a new dodge 3500 club cab with a short box. One of my questions is if a gooseneck can be used with a short bed. My next questions is if when using a gn trailer, I can put the loader bucket on the flat deck that would be over the truck box. this would allow me to get a shorter trailer. Thanks for your help.
   / Gooseneck Questions #2
Yes and yes.
But why would you want a 1 ton truck with a 6' bed?
   / Gooseneck Questions #3
Because driving a long box with a long cab is like driving a limo.
Yes and Yes. But I caution you on the shorter trailer. It may not be long enough to position the tractor to get proper balance between the tongue and axles. IE longer is typically better.
   / Gooseneck Questions #4
I am with you on the short box. The only way I would own another long box would be on a regular cab truck. You can also fit it in your standard garage as you can not with a long box. As for the GN and bucket yes you can do it. The only issue you will have is with a 5th wheel camper or some GB trailers like box trailers. They can get into the back window of the truck in a hurry in a tight turn. For this they make a sliding 5th wheel hitch but nothing for the GN so be careful.
Chris
   / Gooseneck Questions #5
Because driving a long box with a long cab is like driving a limo....
I am with you on the short box. The only way I would own another long box would be on a regular cab truck....
Chris
To each their own, I guess. I would never own another short box; I get way too much use out of an 8' pickup bed. On the other hand, I would be perfectly fine with a 6' flat bed. Go figure.
   / Gooseneck Questions #6
   / Gooseneck Questions #7
You can buy GN trailers with the extended king pin box already on them. Since short box trucks became so popular with the club cabs and 4 doors, the extended pin boxes have become plentiful.
   / Gooseneck Questions #8
Yea, that is a option. The slider hitch for the 5th wheel hitch only is what I was talking about.
Chris
2012 Ford Edge SUV (A50324)
2012 Ford Edge SUV...
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51692)
2001 Dodge Ram...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
2021 John Deere 5045E  Only 86 Hours, Loader Ready, 2WD, Canopy (A52748)
2021 John Deere...
24in Tractor Backhoe Bucket BT4555 (A52748)
24in Tractor...
Turfco Mete-R-Matic III Pull-Behind Top Dresser (A51691)
Turfco...
