jwmorris
Veteran Member
- Joined
- Oct 3, 2007
- Messages
- 1,064
I have wanted to try one for years but they all seem to be priced too high and never last long enough for the owner to lower the price.
About 5 years ago I came across a cheap box blade ($200) on Craigslist and bought it so I didn't have to haul the one from the farm to the house but it has been unused for the last two years.
After I priced out components to build a grader scraper I decided it would be better as a donor since I already had one and started.
I cut out the side plates and punched them for adjustment and will drill them to attach sacrifice skids too.
I took the front and rear blades off the box blade and mounted them to 5" angle iron I had, that will be welded to a section of plate steel so they can be adjusted from level to the skids to 1.5" below.
With a 5 deg angle like the landpride versions.
The next step will be cutting the 3 pt hitch, rear support and ripper teeth from the box blade and welding it to what I have now.
I figure if I don't like it, I can always paint it and turn it for profit but would be interested in suggestions before I stick things together.
I have also thought about using the rest of the "hull" from the box blade as an adjustable back stop, pivot on two bolts, behind the scraper to catch spoils and distribute them at an adjustable height to make it more versatile for spreading say a dump from a FEL, that would otherwise just spill over both blades.
Looking for "I wish" comments before I make it more difficult to change.
Kind of like not thinking about from what side I set the angle so now grading a road will need to be done driving down the left side vs the right...
