Grain Drill vs. Grass Drill
   / Grain Drill vs. Grass Drill #1
bota7800
Washington State
Kubota B7800
We have a few unirrigated acres that I want to improve for horse pasture (to remain unirrigated) the Extension agent said to seed before April 15 and to make sure the grass was seeded with a grass drill - not a grain drill.
I looked at a nice refurbished John Deere 8' drill for sale at what I think is a very good price. If I bought it I could reseed more often rather than paying someone with the equipment.
In front of the large tray is a thin tray with smaller holes that the salesman said is for small seeds like grass. It is calibrated in pounds per acre. Is this a grass drill or is the delivery entirely different? Will this place the seed at the right depth?
   / Grain Drill vs. Grass Drill #2
What you're describing sounds like an F series Deere GRAIN DRILL with small seed attachment. They'll do the job, but not as well as a dedicated "grass drill" or overseeder/power seeder. The grain drill will use the disc openers to disturb the soil, then the small seed attachment merely drops seed on top of that soil, with "cover chains" dragging some dirt over the seed. That worked OK for years. Now there's a better way.
I'd imagine ypour county agent could get more specific with his recommendation. Around here, they either offer to rent you our county's HAYBUSTER brand drill OR refer you to a local equipment dealer who rents out a BRILLION SURE STAND seeder.
It's a difference between an "OK" job and a "GOOD" job. Most of the newer generation of "grass drills" will have closing wheels that firm soil and press seed into the dirt. MAny closing wheel designs resemble a good ol' CULTIPACKER. Our state and county "specs" when doing funded waterway/filter strip seeding REQUIRE a seeder with, or followed by a CULTIPACKER to complete the job.
   / Grain Drill vs. Grass Drill #3
FWJ, I sure enjoy the experience you share with everyone on the forum and it is always so well stated. Knowing nothing about grain or grass drills are you saying that if one were to use a grain drill with a small seed plate and take the extra step of going back over the area with a cultipacker or roller you get similar results to a grass drill?
Thanks,
MarkV
Thanks, FWJ. As Mark said, excellent description.
Our agent did not mention a seeder being available - he just said to use one. I'll check around. I have seen many discussions of overseeders but did not realize that was equivalent to a grass drill.
I will look at the overseeder posts.
Thanks again
   / Grain Drill vs. Grass Drill #5
Thanks,
MarkV
Similar, but not always the same. a dedicated "grass drill" will place seed more accurately in MOST cases.
   / Grain Drill vs. Grass Drill #6
Thanks again
Not all "overseeders" would specifically qualify as a "grass drill". Very similar, but not always the same exact item.
   / Grain Drill vs. Grass Drill #7
If you can rent a grass drill I'd do that unless buying the grain drill with the small seed inserts is cheaper. If you are just planting for pasture the grain drill should do a plenty good. Heck maybe they will rent you the grain drill.
I was on Brillion's website. They have overseeders listed in a different category than the agricultural Sure Stand units. The site specifically says the overseeder is not for pasture or rough conditions. Another problem is they are all too heavy for my 3ph.
There is a small 64" tow behind Brillion GLP64-1 grass drill for sale on eBay. I will watch that one and may bid on it. About 600 miles away, however.
If you use a grass drill do you have to harrow or aerate before or after? Any other prep work I am missing?
Is there anything I need to do to the existing grass?
   / Grain Drill vs. Grass Drill #9
If the existing grass is unsuitable for your uses I'd kill it and any other vegitation. If the existing grass is OK you can leave it if the seeder you are getting is a no-till setup. If the seeder is not a no-till then work the soil. If you have time it would be best to kill existing vegitation (if Unwanted) with chemical, till the soil then let any weed seeds germinate and kill them off with chemical and then seed. Once you break up the soil all dormant weed seeds will sprout.
   / Grain Drill vs. Grass Drill #10
Grass seed needs to be distributed into the top 1/2 normally were many of the other seeds need to be deeper. The spacing is also much closer with a grass drill on the outlets for the seed vs the grain drills. To go over twice with the grain drill in different directions will normally help the seed with a better distribution. Some customers just use a broadcast seeder with full tillage of the field with a packer after.
2017 GMC Sierra Pickup Truck, VIN # 1GTR1MEC6HZ115515 (A44391)
2017 GMC Sierra...
Excavator Concrete Drill, Bucket, and Hydro Thumb (A44502)
Excavator Concrete...
2017 Ford Taurus AWD Sedan (A44572)
2017 Ford Taurus...
2012 KENWORTH T800 CRANE TRUCK (A45333)
2012 KENWORTH T800...
Ford PT 4 Cyl Power Unit (A44502)
Ford PT 4 Cyl...
2019 Club Car 2-Seater Golf Cart (A44391)
2019 Club Car...
