Grapple Design
   / Grapple Design #1
dtd24
Schenectady, NY
98 JD 1070
Let me know what you guys think. Still in the design stage, but she is close. I made this to fit my current bucket even though it's kinda small. I want this to be on and working for spring cleanup, so I figured in order to keep the budget down I will keep the small bucket for now and build a root bucket w/ grapple later down the road.
  • Grapple.pdf
  • Big Green Sexy 1.pdf
  • Big Green Sexy 2.pdf
   / Grapple Design #2
Why did you use such a long hyd cyclinder.
   / Grapple Design #3
It may be me ,but when I click on your picture link .nothing happens .as in I can't get your pics. to open
   / Grapple Design
shaley
that was the smallest I could locate. Maybe you have another source? I wanted to keep it to be 2500 psi. I went to TSC and measured this one all up. I did search on the net a bit, but that was awhile ago. A smaller cylinder would help me straighten that arm out.
kenmac
the files are adobe files. If your computer doesn't have it you can get it for free @ Adobe - Adobe Reader Download - All versions
DaveD
   / Grapple Design #5
I haven't gotten serious yet , but want to fab one also. You might want to mock that design up in cardboard or pine and see if that gives you the area you want to grab. I am mostly interested in brush piles, and I would have (naively) thought that the "area being captured" would be bigger. Would have arced the arms and used a shorter cylinder fmounted farther back. Would be great to have someone who is highly familiar with them weigh in.
Shaley - love your end quote! Hope you last a long time, but hoping to eventually see your wife's garage sale sign!
   / Grapple Design #6
The problem I see with your grapple is that the front claw portion may get in the way of your using the bucket for normal dirtwork. I think you will be hitting it on a lot of things unless you detach it for normal FEL uses.
That's just my opinion from your side elevation drawing. The other PDFs were too large and slow to download on my machine.
   / Grapple Design #7
You are going to have a difficult time finding an off the shelf 2" x 6" cylinder with a retracted length of 20". The closest you will find is a 2" x 8" tie rod cylinder with a retracted length of 20 1/4".
I would suggest that you redesign your grapple around the commonly available cylinders. Most grapples use a 2" x 6" cylinder with a 16 1/4" retracted length. I tried the 2" x 8" on mine and went back to the 2" x 6" as it offered better opening and closing geometry.
Price shouldn't be an issue as they will cost between $65 and $100 each from Surplus Center. They have both 2500 and 3000 psi cylinders.
   / Grapple Design #9
dtd24,
I don't see a big problem with the basic concept. As mentioned, in order to use a stock hydraulic cylinder you may have to mess around with the pivot point locations is all. And like Jim pointed out, the jaw should open more so it won't get in the way when you are not using it.
What concerns me is the geometry of your grapple jaw. Specifically, the shape where it comes backwards like that, and the sharp angle/corner in it.
With the jaw going back like that, as it closes onto "stuff", it may not "drag" or "roll" or push the shrub, rocks, logs back into your bucket. I'm not sure, but it looks like the part going back (on the jaw) might get in the way of the stuff you are grabbing? Second is that if you do get stuff inside those jaws, like shrubs, they might stay there. It looks like it may be hard to dislodge the stuff once it's behind that sharp corner.
Please don't take offense but this is my observation....I know how hard it is to hear about what you are making ... believe me. I think you need to use a more conventional shape jaw like the curved ones or angled ones that don't go towards the back so much.
   / Grapple Design
I never take offense to constructive criticism. I have never even used a grapple, so I am using the information from this site and from grapple equipment website for my design. I looked at it in depth last night (so I could sleep !!) , and I agree with alot of your comments. I am working on a revised design. I will post soon. My job has been stealing alot of my design time. I was most concerned about the mouth opening being too small. My new design is wide open. I love the weapon look of this thing !!!! Drawings are on the way.
We do NOT accept credit cards as payment. (A46443)
We do NOT accept...
2017 FORD TRANSIT AMBULANCE (A43005)
2017 FORD TRANSIT...
AGT Mini Excavator QNT50R (A47809)
AGT Mini Excavator...
Wilmar Load Runner 16 Ton Fertilizer Tender (A47369)
Wilmar Load Runner...
Southbend Double Oven (A45336)
Southbend Double...
Kubota SVL97-2 High Flow Skid Steer  Cab A/C, Rear Camera, Quick Attach! (A46878)
Kubota SVL97-2...
