Grapple Hyd lines... 1/4" OK?
   / Grapple Hyd lines... 1/4" OK? #1
whitedogone
Central Illinois
JD 4120
Just confirming that 1/4" lines and QC are all that are required for a grapple hookup.
   / Grapple Hyd lines... 1/4" OK? #2
Yes...perfect.:thumbsup:
   / Grapple Hyd lines... 1/4" OK? #3
Indeed. I have 1/4" lines and they work perfectly.
Here's what I'm thinking:
The Wildkat grapple came with 6' long 3/8" lines (I think they are 3/8" anyways). These lines have 1/2" male fittings on them. I was thinking of cutting those fittings off and getting 1/4" MPT ends put on them and putting 1/4" QC on the ends of what is already there. I'm not sure what (if any) fittings from DHH would fit this Parker hose.
Then I was thinking of either just wire tieing those lines to the loader arm or making up some kind of bulkhead. If I did a bulkhead I would use another set of 1/4"QC's were the loader QC fittings are so if I want to take the loader off I could disconnet it there as well. The lines to the rear remotes would remain of the tractor all the time.
   / Grapple Hyd lines... 1/4" OK? #5
I use 1/4" lines as well and they work fine.
   / Grapple Hyd lines... 1/4" OK? #6
1/4 inch or 3/8 inch are fine as far as hydraulic flow. Bigger issue is what adapters you need to get to 1/2 Pioneer fittings commonly used on the FEL side. Of course you could also put 1/4 or 3/8 inch Pioneers on the FEL side too. One benefit of 3/8 over 1/4 hose is that they are a little tougher and would be more likely to survive a snag on brush etc without ripping. Ask me why I know. Still, I wouldn't change anything if you already have it.
2019 Doosan LCV6W Towable LED Light Tower (A51691)
2019 Doosan LCV6W...
JOHN DEERE XUV590M (A53084)
JOHN DEERE XUV590M...
2017 PETERBILT 579 DAYCAB (A53843)
2017 PETERBILT 579...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
2016 Ram 5500 Enclosed Service Truck (A52377)
2016 Ram 5500...
2008 Caterpillar 262C Compact Wheel Loader Skid Steer (A52377)
2008 Caterpillar...
