Grass build up under mower deck
   / Grass build up under mower deck #1
Rowski
Veteran Member
North Central Vermont, Jay Peak Area
2004 New Holland TN70DA with 32LC loader, 2000 New Holland 2120 with Curtis cab, 7309 loader
Does anybody have an idea on how to keep (or at least slow the process down) grass from building up under the mower deck? Thanks
Derek
   / Grass build up under mower deck #2
Derek, I clean mine every time I sharpen blades(about 30 hours). Do you have to clean more often ?
Mark
   / Grass build up under mower deck #3
The old man down the road says spray it with silicon spray. I have also heard PAM cooking spray works to keep the build up down.
   / Grass build up under mower deck #4
I suppose different things work for different people, but I tried silicone spray, Pam, and repainting the underside with what was supposed to be a paint that the grass wouldn't stick to. None worked very well. I still can't say I've found anything that was perfect, but the best thing I've found is to spray on a mixture of 75% diesel and 25% motor oil before mowing.
Bird
   / Grass build up under mower deck #5
Bird,
That's definitely different...
How do you clean up the deck... strike a match?
   / Grass build up under mower deck #6
It didn't help the buildup much, but my dad fitted a hose fitting to the top of the mower deck. After mowing, he would attach the garden hose, and rev up the mower. The water would hit all the same places as the grass, and it all came out the chute. Wasn't perfect, but it was cheap, simple, and quick.
I like Bird's suggestion too. Never heard of that, but would be fearful of any sparks /w3tcompact/icons/shocked.gif in the near vicinity...
The GlueGuy
   / Grass build up under mower deck #7
Well, I don't smoke while I'm spraying it./w3tcompact/icons/laugh.gif And I use a sprayer that puts out a very fine mist, so a gallon of that mixture lasted me 3 years. Sometimes when I finish mowing, I blow any grass off with the air hose, and sometimes I wash it off with the garden hose, and sometimes I don't need to do anything to it.
Bird
   / Grass build up under mower deck #8
Do you only mow dry grass? I have heard that wet grass will stick to your mower deck besides loading the engine more than dry grass.
Now, a _completely_ serious question...
Why do you guys clean out under your mower decks? I have seen decks worn out from mowing so much grass that they wore away from the constant sanding action, but I haven't ever seen one rust away. ?????
I have never timed it. I seems like maybe 6 to 8 hrs for the build up to get to the point where it effects the cut quality. I sharpen my blades twice a season. I'm very careful of not hitting rocks. This is on my JD318.
Derek
Bird
For some reason the mixture of diesel and motor oil mixture sounds familiar. Any special weight of oil?
Derek
72in Rock Bucket Skid Steer Attachment (A50322)
72in Rock Bucket...
Echo SRM2620 Gas Trimmer (A49462)
Echo SRM2620 Gas...
1999 24DTA pintle hitch trailer (A52128)
1999 24DTA pintle...
2006 Toyota Tundra 4X4 Pickup Truck (A50323)
2006 Toyota Tundra...
2012 Ford F-250 Crew Cab Pickup Truck (A50323)
2012 Ford F-250...
STIHL TS420 CUTQUICK SAW (A50854)
STIHL TS420...
