dieselfuelonly
I just purchased a Grasshopper 614 that has the separate little oil reservoirs and filter gaskets on each hydro unit.
Seems the filter gaskets are basically obsolete as a Grasshopper part, although Messicks and a few other online sources list them for sale, although who knows if they are actually in stock.
Below is the current configuration -
I was looking through the Eaton parts manual for these hydro units and saw that there are different plates available (see page 6 on the PDF below).
I've found what appear to be the "L" filter bases available and the spin-on filters would be easy to source.
Looking at the parts assembly for a 1998 618, here's what the setup looks like for them with a spin-on filter -
Looks like that setup uses an external reservoir that feeds both hydros, with the #2 hydro flowing through into the filter base of the #1 hydro, which then exits the #1 hydro case and returns to the reservoir.
Since locating the port plate for the #2 hydro that feeds over to the #1 hydro seems difficult, perhaps purchasing two of the filter bases would be idea, and would probably just set up a small individual reservoir for each reservoir with a line to and from.
Anyone ever tried anything like this? I know I can probably source the filter gaskets from somewhere, but they're expensive and seem flimsy compared to a nice spin-on filter and is probably what increased the hydro fluid interval from 500h to 1000h on the newer machines.
