SPIKER
Elite Member
Hi Guys;
by the photo up above you see how the water pools up, that is all on their property. It then saturates the ground and runs twards the drive as it is down hill. the drive is probably less than 4' from edge to line, (was a guess) the pin at the road is only 1' off the edge of drive and the other pin is just beyond the maple at the top right side. the HEAVE is on their property which traps the water.
I know I need to FIX it somehow but if I do tile it I would have to run the tile UNDER the drive and out into my yard. there is not road ditch to run it into. attached here is a pitcher of MY yard looking back twards the road, it is about 150' wide at the road. also note that my septic is in the yard right to the down hill side of the drive and the leach field is running almost all the way down to where the large pool is. then there is a culvert that runs under the road that all that water has to go through (only about 16" dia maybe less as it is about 1/2 collapsed.) Ok now if I do run perf under the drive I have to cut it across the hole yard & septic field to that low drain & culvert, where I could get into some sticky troubles if they think I'm running septic into a road/ditch that has public runoff.....
anyhow here is view looking back tward road from about where the first pic is looking opposit way but about 50 ~100 feet missing between the views.
Mark M
Mark M
