Gravely 20G forward reverse clutch lining replacment
   / Gravely 20G forward reverse clutch lining replacment #1
bigcontender
Binghamton , New York
Gravely 424, 20G
My 20 G is starting to not want to go forward. In looking at the clutches there is a chunk 2" or so missing on the circumfuremce of the reverse clutch. The froward clutch looks worn but I may be able to adjust it.
Looking on e bay I can buy a lining kit Gravely # 40692 for $40 or a clutch and ring assembly Gravely # 42482 for $190.
So the question is how difficult is it to replace the lining? Do you need a bearing press?
   / Gravely 20G forward reverse clutch lining replacment #2
A bearing press is not needed nor is it even a good idea to use it.
There is nothing difficult about it. Just finding the right pop rivet gun can be a challenge.
There are holes on the backside of the clutch to stick a punch so you can remove the trunnion cup and bearing.
The cup comes off first and then the bearing.
Thanks when I ordered lining from Richard's they said to use a spacer so to not pull on the lining directly. Not sure what this is about, said they would include in box , just have to cut spacer to length. Guess I'll see when the parts come in.
   / Gravely 20G forward reverse clutch lining replacment #4
The spacer is to install the pop rivets with a standard rivet gun. I had to hunt all over to find a proper pop rivet gun a few years ago. I finally fouind one at Sears but when I tried to buy one as a gift last year, Sears quit offering that model. I had to hunt for one on Ebay and found it.
Yup
I called Richard's after receiving the parts they explained cutting the roll pin to 3/8" or so. Installed the lining yesterday went very well.
2022 John Deere 410R Sprayer (A53342)
2022 John Deere...
2018 Vermeer Chipper (A51573)
2018 Vermeer...
Husqvarna MZ52 Zero Turn Mower (A51573)
Husqvarna MZ52...
2003 GMC C5500 DUMP TRUCK (A51406)
2003 GMC C5500...
2015 Caterpillar 410L 4x4 Extendahoe Backhoe Loader (A51691)
2015 Caterpillar...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
