Gravely only runs when key is held to "start"
   / Gravely only runs when key is held to "start" #1
goatchay
South Louisiana
Yanmar YM195 Wheelhorse 18 Automatic
Hi to all,
I just purchased a used Gravely PM320 for my dad. I used it the day I bought it and cut 3 acres, it ran flawlessly.
I then parked it (2 days ago) and went to move it today. It starts up fine but only runs as long as I hold the key to the "start" position. As soon as it is released to "run" it kills. All of the safeties seem to be working properly (seat, parking brake, PTO, neutral). Oil and fuel levels are fine. It ran perfectly the last time I used it.
I do notice that when you turn the key to the "start" position ALL THE WAY, that the motor doesn't turn over. I have to slowly turn the key and it bumps the start a little before the key is turned all the way. If you go past this point it won't turn over at all. It's almost like you have to find the sweet spot in the range of the key, if that makes any sense.
The first day I ran the mower, the key did not behave in this way. A general look around and things seem to be fine other than that (fuel looks good in the fuel filter, according to the previous owner both coil packs were changed within the last year, plug cables look fine, etc.).
Any help would be greatly appreciated, I hate to give my dad a mower that he needs to bring someplace to have repaired right off the bat.
Does this point to a problem with the ignition switch itself? I think the manual has a continuity diagram for the switch but I don't have a meter at the moment. Many thanks in advance,
Chris
   / Gravely only runs when key is held to "start" #2
Chris...
Replace the switch.
That will fix the start position problem & most likely will address the run problem.
The switch should be less than $20 and is a very simple R&R. KennyV.
Hi Kenny,
Thanks for the response. I appreciate it. I thought that might be the first logical thing to do, I was just puzzled as to why it worked perfectly fine the last time I operated the mower and just suddenly is defective.
I initially was leaning towards a fuel problem, but that wouldn't explain why it dies after the key is released. I think that the motor might have an electrically activated inlet needle on the carb and thought that could possibly be the problem. I have to take a closer look tomorrow, I ran out of daylight today. BW, it is a Kohler 27 hp motor. I do hope it is as simple as the switch. Thanks again,
Chris
   / Gravely only runs when key is held to "start" #4
bad ground on the "run" side of the key switch. (as others have said) replace
Hi Schism, thanks for the input also.
After some more research through the forums, I'm concerned that I may have shut down the engine improperly. It is a Kohler Command 27hp. It has a fuel shut off solenoid, which I have never heard of. I guess all of the equipment that I'm used to being around is too old to have it.
According to the manual, the mower should be shut down at half idle or greater. I reduced the throttle to it's minumum and let the engine run for a few minutes to cool down before I shut it off with the key. Just an old habit I guess. But apparently this was the complete opposite of what I should have done. I had never heard of intentionally shutting down a mower at higher rpm, thought it would cause it to backfire.
The following is a quote from another thread:
Anyway, I found this from some technical information I had in my files, perhaps it will help. It really depends on the design of the carburetor and the OEM痴 set up on the piece of equipment.
Shut engine down with throttle above idle. Usually throttle settings between シ to セ are sufficient. However, some engines may require shutdown at full throttle to solve.
Engines used on these model tractors are equipped with a fuel shutoff solenoid. This solenoid shuts off fuel to the main jet at shutdown, therefore preventing raw fuel from entering the cylinder or muffler as the engine spins down after the key is turned off. However, at idle speeds the carburetor sources fuel from the idle jet circuit, which is independent of the main jet, and is not controlled by the shutoff solenoid. If shut down at idle, the engine will continue to pull raw fuel into the cylinder and muffler via the idle circuit, possibly resulting in backfire.
In 鍍he old days customers were warned to not shut engines down at high engine speeds because engine damage could occur. This was true as older engines without fuel shutoff solenoids would continue to pull large quantities of raw fuel through the main jet at shutdown and possibly wash down the cylinder walls and cause premature wear and damage. On engines equipped with fuel shutoff solenoids, this cannot happen and no engine damage will occur as a result of shutting down at higher engine speeds.
Due to leaner fuel mixtures brought about by EPA regulations, today痴 engines are more prone to backfire than older non-EPA engines with richer mixtures.
Some customers have found that after the engine breaks-in (50+ hours), they can shut down at idle without backfire.
This is the shutdown procedure recommended by both Briggs & Stratton and Kohler. END QUOTE.
I did not experience a backfire when I shut the mower down a few days ago, but I did today when I was attempting to start it. I think I understand the point of the shut off solenoid, but could not shutting it down as per Kohler recommendation cause trouble in re-starting it?
Is it possible or advisable to remove the shut off solenoid? Thanks,
Chris
Well, still looking around and finding more threads that may corroborate the fuel solenoid theory. Here is a thread that seems to describe what is happening with my mower:
" Default Re: 755 hard to start, won't idle
That solenoid is the fuel shutoff. It has two electrical coils in it. The first one has power while the key is ON, the second only has power while the key is turned to START. The first one only has enough power to keep the solenoid engaged. It does not have power to pull in the solenoid from an OFF condition. The second coil, on during START, is what will pull in the solenoid. The first coil will then keep the solenoid engaged after the tractor is started. When the key is turned OFF, it will disengage and shut off the fuel. This system prevents fuel flow to the cylinders each start sequence until the key is turned past ON, to START. Sounds like the hold coil is not working. Watch the operation of the solenoid during start and run. It should stay engaged until the key is turned back to OFF. BTW, my 755 has never idled smoothly at low rpm. I just let it idle slightly faster than minimum.
JD755's Avatar
You are correct that the white wire from the starter is the connection to activate that second coil. Sounds like that part is working OK. The red wire on the solenoid connector provides voltage to the first coil when the key is ON. That red wire runs to a connector just above the coil. If you have a voltmeter you should be able to check for 12 volts on the back side on the connector where the pink and yellow wires go in to make the connection to the red wire on the other side. If that is OK then the coil is bad. If the voltage is not OK, then you not only have no power to the coil, but you also have no power to the thermo-start controller that activates the glow plugs and the preheat dash light. Does that light work OK? If not it would be a first indication of no voltage to the coil.
When the first coil is not working, it will immediately shut down the engine when the key is returned from start to run. Does the engine act like it is starting and so you return the key to the run position?
In your first post you said it would run if you held in the solenoid. Is that still the case? If so, then the problem is definitely the coil. Sorry to hear about your severe vibration. I have no answer for that.
Probably the best way to say it is, with a bad solenoid as soon as you take the key off START position the engine will not run. Does the engine crank and crank with nothing that seems to catch? Or is there a sense of starting and so you let off the START? You could of course have an additional issue with fuel, but I would solve the solenoid issue first and go from there.
END QUOTE
I think I will push the plunger in manually and then turn the key to "ON", and it should stay retracted, correct? This sure seems like a good way to complicate an engine more than necessary, I've never seen a carb with one of these. I'll post an update tomorrow. Thanks for all of the input.
Chris
   / Gravely only runs when key is held to "start" #7
Its obviously an electric issue. KISS
Start with the back of the switch with your volt meter and go from there. (not saying its not some fuel solenoid, but id start with the simple stuff first)
   / Gravely only runs when key is held to "start" #8
I don't believe that this is your problem but this was a common problem back in the 1950s when cars first changed from 6 to 12 volts. Many had a resistor on the coil so it would only get 6 volts.
But when you put the key in the start position it connected to a wire that went straight to the coil so that the coil got 12 volts while you were cranking it but only 6 volts when you released the key.
If the resistor burned out it would run fine as long as you held the key in the start position but would immediately kill when the key was changed to run position.
   / Gravely only runs when key is held to "start" #9
A simple test to discount the switch would be to remove the fuel solenoid wire and run a temporary wire straight to the battery + post . Start with the key and release , if it keeps running it's the switch .
   / Gravely only runs when key is held to "start" #10
Perhaps a dumb comment, but is it possible the large nut on the rear of the ignition switch (that secures it to the dash) has loosened and the switch has --or is able to be-- rotated/twisted-- if it's mounted that way?
2022 Case TR340B Skidloader (RIDE AND DRIVE) (A50774)
2022 Case TR340B...
2003 PETERBILT 379 (A50854)
2003 PETERBILT 379...
2001 INTERNATIONAL 4700 (INOPERABLE) (A50854)
2001 INTERNATIONAL...
Heavy-Duty Round Bale Trailer - Tandem Axle, High-Capacity Hay Hauler (A51039)
Heavy-Duty Round...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
2020 KUBOTA RTV...
