Grease point verification for KL451
   / Grease point verification for KL451 #1
Kendrick
Vermont
DK45S(Cab)
I need some one to verify that the grease point on the lower end of the arms. I had been good about greasing all the points and just recently it started squeaking while i was greasing for the anual post winter cleanup I realised that the bottom pins on the arms dont have ANY grease points and are probably the reason its squeaking... assistance is appriciated.
I have the qa plate version. it has 2 grease points on the top pin and port of the qa plate and 0 on the bottom.
   / Grease point verification for KL451 #2
The pivot pins on my KL451 were installed wrong; one pair had two grease nipples and another pair had none. I just swapped pins so every one had a grease point. I removed the bucket first (very easy with SSQA interface) to reduce the forces at the pins. The job took maybe 30 minutes and I worked slow. I too noticed the squeak. I don't know if this was just sloppy assembly or if the instructions were wrong. In any case, fix it before wear sets in.
I appriciate it, seems the manual is wrong :( noticed on a parts site just a bit earlier that the diagram they show has it in the wrong places.
Massey Ferguson 1020 (A44502)
Massey Ferguson...
Construction Toy Truck (A44502)
Construction Toy...
2015 BUMPER PULL CENTRIFUGAL PUMP (A45333)
2015 BUMPER PULL...
2016 Kubota KX018-4 (A44501)
2016 Kubota...
Porter Cable 20V Drill (A44391)
Porter Cable 20V...
4Yd Dumpster (A44571)
