TWINKLE_TOES
Veteran Member
- Joined
- Sep 3, 2000
- Messages
- 1,366
I have a new TL421 loader and BT751 backhoe and at 10 hours I greased it. at twenty hours I ran out of grease in the gun. I believed that the gun contained Molybdenum Disulfide as recommended in the loader manual.(High quality grease designated "extreme pressure" and containing Molybdenum disulfide is recommended)
The grease in the gun was "Marine Grease" identified as follows:
Base Type: Aluminum Complex
Color: Blue
N.L.G.I. No.2
Warning: Contains Mineral Oil,Aluminium Benzoate,Fatty acid Hydroxy Complexes and Calcium Dinonylnaphthalene Sulfonate.
Finally hear is the rub. It also contains this label:
:IMPORTANT:
Do not mix greases of different base type. Use a solvent to remove and clean out all traces of incompatable grease before repacking.
I usually use MOLY DISULFIDE from Case in most everything else, which is a Mineral base with Molybdenum Disulfide added.
I sure don't want to pull every Zerk and pin in the tractor and backhoe and remove every trace of incompatable grease.
Seems like both are mineral base even though the marine grease is a little elusive by stating the base type as "Aluminium Complex"
If anyone could help I would really appreciate it.
Color: Blue
N.L.G.I. No.2
:IMPORTANT:
