Greasing BX 60" deck. How much? Kinda confused.
   / Greasing BX 60" deck. How much? Kinda confused. #1
chucky79
Ashland, KY
Kubota BX2370-1, Cub Cadet 1812, Cub Cadet 1810, Cub Cadet 1650
So I spent some time servicing my BX2370's 60" deck the other night and have a question about the volume of grease. When dad taught me how to grease equipment 20 years ago it basically went like this.... Pump a little grease until you see it start to ooze out then stop. Pretty easy, and useful info that has served me well. I noticed on the BX deck though that this isn't the case either because im doing it wrong or some of my grease points were bone dry and seemed to have a 5 gallon reservoir?? The u-joints and deck pivot point both no problems, couple pumps and grease oozed so I stopped. The one on the rear of the deck (that has the arm with spring attached) just wouldn't take any grease no matter how hard I tried to pump the handle so I stopped before I caused problems.. The big question though is the spindles.... I pumped one of them like 10 times and never saw any grease ooze out anywhere so I lifted the deck and checked the bottom to see if it oozed there and the same....no grease. How much grease do you need to put on those spindles? I read somewhere that they are under filled from factory and people have put like 90-100 pumps before grease fill the cup and ran out on bottom. Im ok with doing that I just wanna make sure its correct and im not damaging anything or blowing out some sort of seals (if they exist) on the deck. Give me a little insight here please people...
   / Greasing BX 60" deck. How much? Kinda confused. #2
Here's what I've been taught. Other may have different ideas but this is what works for me.
On a u-joint I grease till all four joints have grease coming out. Then you know the whole joint has fresh grease. On a vehicle I use a waterproof grease. The grease is about three times more money but rear u-joint on my Cummins went from being replaced yearly to once every five years. This is a win as replacing u-joints is not my favourite job.
Ball bearings are a bit different. If you over grease you can push the outside seal off. On a mower spindle I just give three shots and quit since they don't need a whole lot of grease to survive. If I'm greasing a bearing in a pillow block usually one or two shots of grease is lots. The bearing will warm up and push the extra grease out and if you put to much in they can overheat.
   / Greasing BX 60" deck. How much? Kinda confused. #4
I only give the spindles one pump of grease each,usually after each mowing.The excess grease is collected in the large cup between the spindle and the blades.I don't think the grease in the cups actually serves any purpose.The cups are there mostly to protect the bottom of the spindle from being damaged.
   / Greasing BX 60" deck. How much? Kinda confused. #5
Wow, after each mowing? I service my mower once a year, in the fall when I take it off. No problems yet after 4 years.
   / Greasing BX 60" deck. How much? Kinda confused. #6
I posted this awhile back, but here is a copy.
I have replaced many bearings on my Dixie Choppers due to sand and water. The spindle full of grease is supposed to take up space so water can't get in and lessen the replacement time. The sealed bearing is supposed to seal out dust, sand, etc.
On the subject of bearings, Most of you probably don't know what kind of bearings you have. About the only way for you to know would be to have replaced those bearings.
If you have sealed bearings, and you keep pumping grease into it, you will probably blow the seals, and then you have an unsealed bearing.
Some say that they are greasing every couple days, or hours. Seems like a waste to me. The bearings actually run in the oil extracted from the grease.
Excerpt:
Too much grease volume (over-greasing) in a bearing cavity will cause the rotating bearing elements to begin churning the grease, pushing it out of the way, resulting in energy loss and rising temperatures. This leads to rapid oxidation (chemical degradation) of the grease as well as an accelerated rate of oil bleed, which is a separation of the oil from the thickener. The heat that has been generated over time along with the oil bleed eventually will cook the grease thickener into a hard, crusty build-up that can impair proper lubrication and even block new grease from reaching the core of the bearing. This can result in accelerated wear of the rolling elements and then component failure.
If you really want to know what the spindle looks like when you think it needs grease, take the time to break down the spindle and bearings and take a look, analyze the situation and go from there . It's your grease gun and your machine, do as you wish.
If you search the internet for over greasing , there are many articles on the subject.
New technology is using IR and Ultrasound to monitor and troubleshoot bearings.
With IR you can see the change in insufficient lubrication, normal and over greasing.
With Ultrasound you can hear when the bearings pick up the injected grease.
J.J.
   / Greasing BX 60" deck. How much? Kinda confused. #7
......What kcender said. The BX 60inch mower OE manual doesn't say how much. It just says to grease the illustrated zerks. Back in 2009 my MMM would not take any grease on one zerks called the "balance shaft". I took that joint apart several times, checked the zerk, and even sanded the joint articulation...........several times. It finally would take some grease after a lot of grunting. I suppose a commercial high pressure system would have fixed that one. A couple pumps should be enough on a regular basis.....probably 10-20 hours of mowing. Here's a picture of the underside where the spindle cups collect the grease where you can't see it otherwise. 782.jpg
Cheers,
Mike
   / Greasing BX 60" deck. How much? Kinda confused. #8
You cant see the grease coming out on BX mower deck spindles unless the blade and cup is off. I pump about 5-8 times each 3 spindles for every 5ish times mowing which is almost once a month. If you are pumping over 12 times, then you gone way too long without grease.
   / Greasing BX 60" deck. How much? Kinda confused. #9
+1 for what JJ said. Most of the mower spindle bearings are sealed and don't need grease. My dealer told me the same thing when I bought my ztr last year. He also said guys thinks things with grease zerks are better quality so they put them on there. If you fill the cavity between the upper and lower bearing with you risk breaking the seal and reduce bearing life.
   / Greasing BX 60" deck. How much? Kinda confused. #10
For what its worth this is my experience which tallies with just about everyone else's input . If its a UJ pump until its just starts to peak out but dont go mad. If its sealed,grease little and often so you dont blow out the seals . I use High speed grease on my mower deck but I would not recommend Moly . That just dries up at high speeds . I think molly is more for links under High pressure loads such as excavator buckets.
For every two hours work I put two squirts from a regular cartridge size gun in the cutter bearings . The tension pulley does not need as much . The grease nipples on the plain bearings of foot pedal etc , probably only need a squirt every six months or so . No point wasting grease , its not cheap.
U joints I do maybe every two months when I take out deck , clean it up , switch blades over . I take the blades out, sharpen them up and put in the fresh . I keep a spare set so I can sharpen the others and balance them at leisure . Way to many folks dont do this often enough .
I think its good practice to change blades regularly . Less load on machine , gives you a chance to thoroughly clean and inspect everything then slide it back in.
Decks take a helluva lot of punishment . You have to keep up the maintenance . Kubota decks do a great job though when they are sharp and well adjusted .
   / Greasing BX 60" deck. How much? Kinda confused. #11
Duckslayer re sealed bearings . Sealed bearings can last many years in machinery that is not exposed to the elements BUT they will go eventually . They will dry out and start to howl really badly . If you ignore the howling until they start smoking then you could be up for some serious damage. Trouble with mower decks is they are so noisy anyway that the howling can be hard to detect . I have seen sealed bearings go **** on woodworking machinery and its pretty scarey. But that's only because the boss refused to believe they needed replacing until Bang ! Fire Hazard and explosive sawdust . Nasty.
   / Greasing BX 60" deck. How much? Kinda confused. #12
While it is true that I don't know what type of bearings are in my mower deck I don't think it is really possible to over grease them.It seems that they are designed to allow excess grease to collect in the cups so there must be a passageway built into them for this purpose.The first time I have sharpened the blades on a new deck,four new decks on four different machines,there is always excess grease in the cups from when the machine was prepped by the dealer.This shows that the dealer is making sure a new deck has lots of grease and is not concerned with over greasing the spindles.I think Kubota designs the decks to allow for the average person to maintain them,not for a very precise amount of grease at a very precise interval.
   / Greasing BX 60" deck. How much? Kinda confused. #13
My John Deere zero turn grease fittings on the spindles will not let the grease push out the side of the shaft. The first time I greased the spindles I pumped grease waiting for grease to ooze out but I heard a pop. After investigating the shaft popped up and the spindle would not turn. I took a small nail and had to relieve the pressure. Let's say grease does not have a pleasant taste. The owners manual just says grease the spindles. My 60" 3 point finishing mower will ooze a little grease past the shaft when it is full.
So much knowledge and experience but so many different opinions.... Yet many tractors and mowers running trouble free no matter what the preference. Guess the key is to make sure you at least do something instead of nothing....
Thanks guys.
   / Greasing BX 60" deck. How much? Kinda confused. #15
Thanks guys.
Pretty much . It took me a while to come up with a formula for the conditions my tractor works in. Im sure you will be fine though. Its hot and dusty down here so you have to grease a bit more often to be safe . The grass is tough ,the gum leaves are dry crumbly and acidic , the heat/dust sucks the oil out of grease quicker. If ever there was a graveyard for cheap ride on's its Australia . Every time I go to the hardware house I pity the poor soul who buys a blingy ride on and Im thinking 'two years max'. If he's lucky.
I know guys who never do maintenance though. They get away with it right up to the point of failure then blame the machine ! Or they push the machine outside its envelope and then spend a fortune saving five ten minutes extra work . Silly. I was taught to look after my gear from the cradle.
   / Greasing BX 60" deck. How much? Kinda confused. #16
Thanks guys.
was just thinking the same!
i've always been taught the same. i use the high-speed synthetic in all of the bearings on the BX (i.e. deck spindles) and a 5% moly on bushings and pins (i.e. loader and backhoe)
my dealer recommends/sells/and uses Lucas products and told me to use their "Red and Tacky 2" on my Kubota. I read Lucas website and may use their Xtra Heavy Duty instead on the deck spindles as it specifically states that is good for high speed bearing applications. Im sure the Red and Tacky 2 would work fine as well though to be honest. Probably all better than the OEM stuff being shot in there from factory.
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A59905)
2018 INTERNATIONAL...
2006 Mercedes-Benz Unimog 405 4x4 Flatbed Truck (A56858)
2006 Mercedes-Benz...
2020 INTERNATIONAL TANDEM AXLE SLEEPER (A58017)
2020 INTERNATIONAL...
2016 New Holland Boomer 47 (A60462)
2016 New Holland...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2019 INTERNATIONAL...
DRAGON 500 BBL FRAC TANK (A58214)
DRAGON 500 BBL...
