greasing caster wheels
   / greasing caster wheels #1
Mosey
Veteran Member
Conifer, Colorado
2000 New Holland TC29D with 7308 FEL, and top & tilt. 1950 John Deere B. 1940 Farmall A.
Greasing the caster wheels on my LandPride FDR2572 is getting to be difficult. If I just try to pump it in, it only comes out on one side of the bushing, which makes me worry that it’s not getting to the other side. So, I try to push or pull the wheel up tight against the side the grease is coming out to force it to go out the other side. But, that’s hard to do on a caster wheel because it swivels around and won’t stay still. I need 3 hands, one to hold the caster fork from swiveling, one to push or pull on the wheel, and one to pump the grease. Anybody else have this problem? Maybe it’s time to take them apart and clean them up good.
   / greasing caster wheels #2
I wouldn't worry about it. I just spin the wheel a few times after I grease it or you can even turn it while you're greasing it. There's not a lot of pressure there so any grease that get's in there will do it's job. True, if you feel like they're all gunked up maybe it's time to clean them.
48" Pallet Forks  (A52384)
48" Pallet Forks...
2018 MDB T5E MDB DISC MOWER (A51243)
2018 MDB T5E MDB...
2005 Toro Workman 175 Sprayer Cart (A50322)
2005 Toro Workman...
2004 Ford F-250 Pickup Truck, (A50323)
2004 Ford F-250...
2023 AVANT 735 COMPACT WHEEL LOADER (A51242)
2023 AVANT 735...
2016 Ford E-350 Enclosed Service Van (A50323)
2016 Ford E-350...
