great day plus some seat time!
   / great day plus some seat time! #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
I just had a great day and wanted to share it with my tractor buddies.
Today I finished up a bunch of honey-do's and farm chores, including a good amount of seat time.
First I eradicated 11 more wasps nests I found around the barn and house. ( My wrist is back to 95% from fridays sting ).
I pulled all the tractors out of the barn and cleaned it up. I had all my tools scattered around from the last two weeks of tuneups on the N's, and the lawnmowers. All gas engines now have stabil in the fuel. I sat down and rebuilt a spare carb I had for a B/S engine. It came off my 8.5hp unit.. but i see that it is the exact same one on my 12.5 ( different jet? ) So now.. courtesy of sears extended service replacing my old carb last year instead of rebuilding it.. I now have a good spare. It had the float needeld glued tight like the last one I pulled apart.
Next week I tackle the tsx 241 from my 8n and try to remove the broken idle screw.. etc. I've got my dremel charging up for that problem already.
Lets see... Hooked up the box blade to the 8n and boxed up the maneuer pile.. fiddled with the NAA and brush hog.... Boy.. I would rather have the boxblade on the machine with live hyds.. but the mower goes a bit better on the NAA as it has turf tires.. and the box blade machine really needs the aggs to dig in around the soft pile. I got pretty good with the tranny and hytrol lever... In the end I had pushed up a pile about 3.5 feet tall, and 5' around.. which had been spread out to about 10' and 1-2 foot tall... that old 8n is running better than ever before with the other carb I put on it. Starts on the 1st rev, and has way more power and better top rpms, and smoother idle at lower rpms. I still think I have her running a bit rich.. but I drop it an 1/8 of a turn every time I use her to see where she wants to be. I'm trying to ballance power out, and still not get any smoke. I think I peffed it today, as I got a few good hours on her. Was noce to see that even at hot idle after hours of work she still holds 18 psi.. and 35 at throttle.
Naa still has it beat with pressures in the high 40's at throttle, and high 30's at hot idle.
Lets see.. rebuilt 3 battery chargers that have been setting in the 'fix' pile, and also put an old kmart 'benchtop' cordless drill back together that has been apart in a box for oh.. 3 years... it is now charging up and seems to work fine.. for an 18$ drill that is 9 years old.. he he..
Tended to 2 turkeys that I just pulled out of the incubator today... they're big enough for a brooder box and lamp now.
One of my hens is setting on eggs.. so looks like I'll be moving chicken pens around and possible building another..
I finished the evening off with mowing for about an hour.
Well. I'm whipped. I'm gonna have a glass of tea, and a hot shower and hit the bed.
later...
Soundguy
   / great day plus some seat time! #2
Glad to hear you had such a good day. I had a good one, too. I got my mowing done. I used my box blade to rework the drive and get the gravel up nice and level. I put a couple new 1000 amp batteries in an F-450 diesel service truck I just got and put a new 1000 amp deep cycle/starting battery in my tilt bed trailer to power the hydraulics and the winch. I also bought an older F-350 crew cab dually diesel and got my little riding mower within three parts (battery, ignition switch and belt) of being back in service.
Not nearly as productive as yours, I'd say, but I'm happy with it. /forums/images/graemlins/smile.gif /forums/images/graemlins/cool.gif
   / great day plus some seat time! #3
There's just nothing like a sucessful day of hard work and accomplishment, especially if some of it is on the tractor.
Me, I only got an hour and a half in on the tractor pulling bush stumps and stuff like that. First I had to put the BH back on the tractor for the first time, which wasn't too bad. Anyway, glad you had a good day, we all deserve them once in a while.
Cliff
   / great day plus some seat time! #4
Same here.
I did my 50 hour service!! Drained the transmission/hydro fluid, cleaned the suction screen, and replaced the filter. Then drained the front axle fluid. Then drained the engine oil and put a new filter on. This went a lot smoother than I thought it would. Final task was to grease everything and make sure nothing was dripping.
Then took it out for test drive/leak test. Went over to the neighbors house and he was mowing grass. He says, why don't you hook up your finish mower and we'll knock this out then go out to eat. When your cutting 12' swipes it doesn't take long to mow 8 acres.
Got home from the restaurant after dark and sat out BS'ing and looking at the stars!!!
It was a good day today.
   / great day plus some seat time! #5
Sounds to me like you had a good day too Soundguy....
The wife and I took the day off and visited the Medina County Fair here in Ohio. At 5PM we were ringside for the tractor pulls. It was a great day weather wise and a really good show, who could ask for more?
I've only seen one tractor pull.. but would love to see more. I keep misisng the local one here due to work. They don't advertise it till the month before, and byt the time I see the sign on the side of the road it is too late for me to get a day off.. Oh well.. one day..
Soundguy
   / great day plus some seat time! #7
Geez - I drove my kids to soccer tournaments and watched them play all weekend, then got home to watch one cutting the grass on one tractor (for the first time in 3 weeks), 2 raking it up, and the 4th loading and removing it with my other tractor. Me - I was stuck painting some doors I haven't been able to get at for a month. Seems to me the kids had more fun than I did! Still it was a good weekend. Kids did well in their games and made me proud, and even though I didn't get on my own tractors, it made me feel good to see the whole crew out working together and they did a good job to boot.
Plus my 7 yr old got to combine 10 acres of grain with the neighbour, so that was the the highlight of his weekend.
</font><font color="blue" class="small">( Plus my 7 yr old got to combine 10 acres of grain with the neighbour, so that was the the highlight of his weekend. )</font>
Awesome experience.
My first tractor experience came from riding to the pasture with my grandfather on his old ford tractor, and then watching him disc or plow while I played with sticks and rocks.. etc..
Soundguy
   / great day plus some seat time! #9
Soundguy I have taken the liberty to include a link to the NTPA National Tractor Pullers Association. Maybe you can get lucky and locate a pull near you that will also fit your schedule. The local Ohio Association has been going strong for some years and it's always been a real adrenalin rush to see all the different classes compete.
NTPA click here
Most appreciated!
Soundguy
1994 Alumatech Frameless Dump Trailer (A50514)
1994 Alumatech...
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
Case 830 Tractor (A50514)
Case 830 Tractor...
2013 Ford Escape SUV (A50324)
2013 Ford Escape...
2025 Kivel 24in Forks and Frame Mini Skid Steer Attachment (A50322)
2025 Kivel 24in...
2008 FORD F-750XL SUPER DUTY ASPHALT DISTRIBUTOR T (A51243)
2008 FORD F-750XL...
